Project of the Month built by Rustkolector
Home Model Engine Machinist > Showing Them > A Work In Progress > The Beginning of another I. C. Engine,
Old 10-22-2017, 12:32 PM   #41
yves-berger
Default HK carb
Please could provide the reference/type of carb you bought at Hobbyking ?
Yves.
yves-berger is offline
Old 10-22-2017, 08:30 PM   #42
DavidLloyd2
DavidLloyd2's Avatar
Liked 67 Times on 27 Posts
Likes Given: 160
Default Carb from Hobbyking
Yves.
The Carb for the Rockerblock engine is a
APS FS91AR carb assy 0.91cu.in 15CC
sku:FS91AR-80801X
Hope that helps
DavidLloyd
DavidLloyd2 is offline
Old 10-23-2017, 08:06 AM   #43
roxwellmax
Liked 12 Times on 4 Posts
Default
Good morning,
I run the Rockerblock engine on a home made carburettor designed by Chuck Fellows, very easy and quick to build and the engine runs a treat. I can let you have the plans if required.
Max.
roxwellmax is offline
Old 10-23-2017, 09:39 AM   #44
yves-berger
Default Carburettor
Thanks a lot to both of you for your answers !
I'm really planning to build that engine, even if it will be some delay before I can do it.
But, I'll do it for sure, I'm interested by both solutions (buy & build), and I am curious to see how to build such carb.
Therefore, I would enjoy if you could already provide to me the drawings.
Old 10-23-2017, 03:41 PM   #45
roxwellmax
Default
Carb plans attached. Good luck.
Max.
Old 10-24-2017, 12:16 PM   #46
yves-berger
Default DIY carb
Thanks a lot.
When I was a boy, around 50 years ago, somebody gave me an RC plane engine, and the carb was quite similar to the one you provided the drawing !
The carb needle was missing, and as I was mechanically speaking, alone, I spent a long time, trying unsuccessfully to let it run.
To build such a carb would be quite a sort of 'revenge' on that for me !
New Beginning. It all starts somewhere lndshrk25 A Work In Progress 7 05-14-2017 01:19 AM
Help at the beginning of the road hussien95 General Engine Discussion 11 02-05-2015 10:55 AM
the beginning of my shop!!! :D Speedy The Shop 27 11-19-2009 01:47 AM
Start at the beginning Bogstandard The Break Room 4 07-20-2008 03:58 AM
The Beginning of a Webster Jack Photos and Videos 15 12-13-2007 12:02 AM
