Project of the Month built by gbritnell
Home Model Engine Machinist > CNC and 3-D Printers > Software and Programming > Electronic Dividing Head using the Arduino
Old 07-28-2017, 04:28 AM   #251
jeep534
Liked 3 Times on 3 Posts
Default
Your english looks fine from here I would like to know more about your indexers with more (bad english) and pictures...
Thank You
archie
Originally Posted by almarghi View Post
I have build two of them, using arduino nano with some small changes (regarding the outputs) and I didn't have any problems with the algorithm, but with the key voltage levels on the analog input. Both worked perfectly from the first time, without any issues.
Since I don't trust any contraption without feedback, I oversized all power components - motors and power supplies - and it worked. For supplying the arduino board, I have build a swithing 9V dc-dc converter and I have used its onboard 5V linear supply.
in the attached picture you can see a bearing cage with 64 holes. No position error detected.
Please excuse my bad english,
Alex
jeep534 is offline
Old 07-28-2017, 02:55 PM   #252
cfellows
cfellows's Avatar
Liked 758 Times on 486 Posts
Likes Given: 3
Default
Thanks for posting, Shopshoe. It's great to see folks getting some good out of this thread.
cfellows is offline
Old 08-01-2017, 10:14 AM   #253
almarghi
almarghi's Avatar
Liked 1 Times on 1 Posts
Likes Given: 22
Default
Hi jeep534,
there is not much to tell. You can see both of them in the photos. One of them is vertical, the other horizontal.
The vertical one is a gear belt type, 1:5, with an normal XL037 belt. There is only one bearing inside, double row angular contact, SKF3306 ATN9, to be as flat as possible. My milling machine is an Optimum BF20L, small but not very rigid , so I have to be as low as possible with the spindle.
The second dividing head, is a 1:80 HarmonicDrive personal construction. Unfortunatelly I lost all photos I made during construction. I have only the project drawings left and I can take some pictures of the completed head.
Since I work mostly with aluminium, large diameters with thin walls, the Harmonic Drive head has now a 6jaw , 100mm chuck to prevent deformation.
almarghi is offline
Old 08-02-2017, 08:34 AM   #254
Captain_Obvious
Liked 9 Times on 8 Posts
Likes Given: 12
Default
Hi all,
Sorry for the delay, but I've been a bit busy lately. I finally got the dividing head somewhat finished. I still need to make a box for the PSU and the stepper driver, but the actual dividing unit is now complete. I haven't tried it out yet, but I don't see why it wouldn't work just fine.
As I mentioned before, I did contemplate making some sort of a spindle brake, but it seems pretty pointless, as the steel reinforced polyurethane belt is much more rigid than the original rubber belt I was planning to use. I'll have to take some test cuts and see how rigid this thing actually is.
The spindle housing is a solid chunk of steel with a hole bored through and a recess milled at both ends for the 6007 ball bearings. Not ideal bearings for this purpose, but they do seem good enough. If I choose to use angular contact bearings, I still have plenty of material so I can bore the bearing seats a bit larger. The motor bracket is aluminium.
The spindle is an ordinary straight shank ER32 collet holder and the stepper motor is a 3Nm Nema 23 unit running at 48V.
Captain_Obvious is offline
almarghi Likes This
Old 08-03-2017, 05:24 PM   #255
ddmckee54
Liked 20 Times on 16 Posts
Default
Pink with white polka-dots? Not exactly your average machine tool color scheme. Did you lose a bet and have to paint it that color?
Don
Too many irons, not enough fire.
ddmckee54 is offline
Old 08-04-2017, 06:04 AM   #256
Captain_Obvious
Likes Given: 12
Default
No lost bets here. I firmly believe it should be mandatory to paint all metalworking machinery pink. Polka dots are optional due to their mildly psychedelic effects which may result in either futuristic machine designs or severed limbs.
Besides my shop is already full of boring green and grey and black machines.
2
People Like This
Old 08-11-2017, 01:00 AM   #257
markba633csi
Default
Let's hope the severed limbs are just a hallucination
markba633csi is offline
Old 08-12-2017, 06:07 AM   #258
almarghi
almarghi's Avatar
Likes Given: 22
Default
just finished a m0.8, z153 gear. No problems on dividing
almarghi is offline
Old 08-12-2017, 03:06 PM   #259
tjwal
Liked 4 Times on 3 Posts
Default
Nice. Is that a focusing ring? I 3d printed some for my son. I've since acquired a cutter but haven't tried it yet.
tjwal is offline
Old 08-12-2017, 06:27 PM   #260
almarghi
almarghi's Avatar
Likes Given: 22
Default
yep! You good guess! 115mm inside, 15mm wide
almarghi is offline
Electronic Dividing Head cfellows Tools 23 08-10-2013 02:29 AM
Rotary Head/Dividing Head Question chucketn General Engine Discussion 6 02-13-2012 03:18 PM
Dividing head m_kilde Tools 25 04-11-2011 09:17 AM
Dividing head Richard1 General Engine Discussion 9 09-15-2009 07:47 AM
Look Ma, no dividing head. John S Photos and Videos 7 07-15-2008 05:08 PM
