Home Model Engine Machinist > The Tools and Tips > Tools > bad 4 jaw
Old 12-23-2017, 03:38 AM   #21
Cogsy
Cogsy's Avatar
Liked 486 Times on 378 Posts
Likes Given: 477
Default
You'll get so good at dialling in on the 4 jaw you wont need a 3 jaw (unless you need to machine hex stock). The first time I mounted my 4 jaw I didn't take it off for 6 months, but now I'm lazy and my 3 jaw does most of my work.
Al.
______________________
I'd like to be a perfectionist, but I lack the patience...not to mention the skill...
Cogsy is offline
Old 12-23-2017, 02:58 PM   #22
mcostello
Liked 32 Times on 29 Posts
Likes Given: 8
Default
You mean You cannot use a 4 jaw for Hex stock? Must be doing something wrong.
Lancaster, Ohio USA
mcostello is offline
Old 12-23-2017, 07:03 PM   #23
john_reese
Liked 4 Times on 4 Posts
Likes Given: 5
Default
Originally Posted by itowbig View Post
oh yes but it will require making every one of them. i wont trust this chuck the way it is. . ive ordered and recieved a 4 inch 4 jaw from little machine shop . i just broke down and got a good one. my 3 jaw is 0.27 off and ive screwed it up now by trying to grind it true. so is flippin usless now too.
It was practical to make new screws for a 12" steel body chuck. For a 4" cast iron (import) chuck it is not worth the investment in time.
john_reese is offline
Old 12-24-2017, 07:32 AM   #24
Cogsy
Cogsy's Avatar
Likes Given: 477
Default
You're right, I don't know what I was thinking. Perhaps it was a triangular part that forced me to change chucks once, I can't remember, but I do know I couldn't use the 4 jaw (or perhaps I just screwed up ).
Al.
Cogsy is offline
Old 12-24-2017, 09:42 AM   #25
Nick Hulme
Liked 64 Times on 48 Posts
Likes Given: 30
Default
The 4" Pratt-Burnerd which came with my Super 7 had half the square socket broken off on top of one screw, but they used UNC screws so a trip to the bolt shop and I had 4 new, rather chunky grub screws with nice new hex sockets, the correct thread and length, and which just needed a slot in the right place to drive the jaws. I can't see why they need to make small 4 jaw chucks more complex than that
W.C. Fields said "You can't cheat an honest man", he should have followed that with "But, you can always find a credulous fool if you need one"
Nick Hulme is offline
Old 12-24-2017, 11:28 AM   #26
goldstar31
Liked 340 Times on 291 Posts
Likes Given: 537
Default
[QUOTE=Nick Hulme;300252]The 4" Pratt-Burnerd which came with my Super 7 had half the square socket broken off on top of one screw, but they used UNC screws so a trip to the bolt shop and I had 4 new, rather chunky grub screws with nice new hex sockets, the correct thread and length, and which just needed a slot in the right place to drive the jaws. I can't see why they need to make small 4 jaw chucks more complex than that [/QUOTE
My Myford Super7 B( Burnerd) 6" independent also had broken screws when I bought it.
Probably caused by trying to push work along with two opposing screws firmly locked. The Two Bees Syndrome- Brute Force and Bloody Ignorance.
One day I'll braze them but with care they still work.
2 years ago at the Ally Pally, I got a 4 jaw self centring chuck for the two Myford machines thought that if care was not taken that it would also be a possible candidate if non concentric or non square materials were being held.
goldstar31 is offline
Old 12-24-2017, 06:32 PM   #27
itowbig
Liked 16 Times on 16 Posts
Default
Yes i do like the 4 jaw much better, but it will take me a bit to get used to quickly setting it up. Im pretty happy with the new 4 jaw . I got the 4 inch with the back plate. it takes up a lil more room , but im happy with it.
Sid
itowbig is offline
Old 12-24-2017, 06:34 PM   #28
itowbig
Default
i agree completly. ill find another use for it some day. for now it sits in the scap box.
Sid
itowbig is offline
