Project of the Month built by Rustkolector
Home Model Engine Machinist > Showing Them > A Work In Progress > PeeWee V4 slow build
Old 02-04-2018, 10:57 PM   #171
michael-au
michael-au's Avatar
Liked 328 Times on 167 Posts
Likes Given: 785
Default
Good work Al, block looks really good
michael-au is online now
Cogsy Likes This
Old 02-19-2018, 12:57 PM   #172
Cogsy
Cogsy's Avatar
Liked 504 Times on 390 Posts
Likes Given: 495
Default
Instead of the pistons I figured I'd attempt the centre main bearing first so I could finally mount the crank properly. I started with a chunk of 1-1/2" LG2 bearing bronze but I couldn't face another marathon hacksawing session, so I used a slitting saw to cut it in half instead. Once I had 2 pieces I took a quick skim cut to smooth the cut sides.
Click image for larger version
From there I soft soldered the two halves back together. I tried to get both halves lined up but it's a tricky job that needs more than two hands and it's not critical at all, so rough enough was good enough.
Then it was into the 4 jaw and adjusted til the join was centred. I used the point of a live centre as a reference and it took no time at all.
I would like to say it was then a simple boring and turning operation but in reality the thin thrust edges of the bearing deformed during machining and took a lot of fettling to reshape and adjust to fit. Then a quick flash of the torch (after marking both halves to keep them matched) separated them ready for fitting. After having seen how Michael-au machined his big-end bearings using a dummy conrod end for support while turning, I'm going to copy his method for my big-ends and I expect they'll go a lot easier than this one did.
Finally, I slopped a bit of light weight oil on everything, temporarily fitted the crank and spun it by hand (with a spanner) to free it up a little. Once I was happy everything was properly aligned and fully lubricated, I spun it over at a few hundred rpm using the lathe to drive it and it now turns nice and smoothly, though it's still got a little ways to go before I'd call it free-spinning.
Al.
______________________
I'd like to be a perfectionist, but I lack the patience...not to mention the skill...
Cogsy is offline
michael-au Likes This
Old 02-19-2018, 01:20 PM   #173
Cogsy
Cogsy's Avatar
Likes Given: 495
Default
And with the crank now in place, I could finally start on the pistons. The first operation is the most fun, with a nice and simple turning job to make some cute little piston blanks. I used a reground parting blade to cut the ring grooves (they're about 0.035" wide from memory) and took a partial depth parting cut at the correct piston length (plus a smidge for final facing) leaving a decent stub, machined concentric to the piston, to hold onto for further operations.
Onto the mill, I held the stub in a 5C collet in a square holding block and centred with the ever-useful coaxial indicator. From here cutting the conrod clearance slot was a simple piece of milling.
Laying the collet block down and rotating it 90 degrees ensured the gudgeon pin hole was perfectly orthogonal (that's a fancy word for perpendicular I've been wanting to use ) to the slot I'd just milled. Then it was just a matter of repeating for the rest of the bunch (7 in total for some extras for safety and maybe a key-chain or something).
Then they were returned to the lathe and parted off from the stubs. I elected to hold them by the stub for the parting to make sure the fragile pistons weren't damaged, then I lightly chucked each piston in turn, wrapped in some protective masking tape, and faced off the final couple of thou to finish. These 4 are the ones destined to go up and down really fast and make lots of noise.
Really happy to be getting the main rotating elements done now. Hopefully soon I'll be able to spin the crank and have things going up and down which will amuse me for hours at a time.
Al.
Cogsy is offline
Old 02-19-2018, 01:35 PM   #174
michael-au
michael-au's Avatar
Likes Given: 785
Default
Coming along nicely
Cogsy Likes This
Old 02-19-2018, 01:43 PM   #175
Brian Rupnow
Liked 4044 Times on 3214 Posts
Likes Given: 37
Default
Great work, as usual Cogsy. I'm watching.--Brian
Brian Rupnow
Brian Rupnow is offline
Cogsy Likes This
Old 02-19-2018, 10:48 PM   #176
Herbiev
Herbiev's Avatar
Liked 286 Times on 243 Posts
Likes Given: 92
Default
Looking great so far Cogsy. Keep the pics coming.
Herbie
Hallett cove
South australia
Herbiev is offline
Cogsy Likes This
Peewee V4 stevehuckss396 A Work In Progress 276 03-22-2014 12:23 AM
Demon V8 Slow Build Maxine A Work In Progress 73 07-05-2013 04:21 PM
Question for Steve Huck on PeeWee V4 Cam kuhncw General Engine Discussion 2 11-11-2011 04:26 AM
Plans and castings for PeeWee jimmy-1 Buy / Sell / Trade / eBay 3 02-14-2010 09:34 PM
How Slow Can You Go bretk Photos and Videos 49 07-08-2009 02:26 PM
