Project of the Month built by TonyM
Home Model Engine Machinist > Building Them > General Engine Discussion > Pac Mag Steam Engine
Old 10-12-2017, 02:45 PM   #1
The_Paso_Kid
Liked 62 Times on 30 Posts
Likes Given: 18
Default Pac Mag Steam Engine
Has anyone made the steam engine from the Mechanical Package Magazine (Pac Mag) Volume 1, No. 3 ?
Picked this one up years ago and just recently stumbled upon it again while moving some boxes around. The cork has long since deteriorated beyond use and the piston is missing [probably why this engine was never completed] The plans show dimensions for the piston so should not be a problem to replicate a new one.
Just wondering if I should leave the kit as it is and just build a complete engine from scratch?
The_Paso_Kid is offline
2
People Like This
Old 10-12-2017, 10:07 PM   #2
JCSteam
Liked 32 Times on 30 Posts
Likes Given: 183
Default
I love these types of things. Kits for kids from yester year.
Looks to be a fun build, though think twice about the tin can boiler, as I'm sure you'll be aware, a thin steel boiler is a no go. It's a fairly simple design, as occilators are. Look forward to seeing it come together. If it was me I'd copy the kit, and keep the kit as original, would be better if it were all complete though.
Ps Sterno gel fuel is still used to fire these little engines. I've even used hand sanitizer. Though brass, or copper boilers are preferred. (I'll go hide while the do not use brass for boilers brigade have their say).
JCSteam is offline
Old 10-14-2017, 10:50 AM   #3
Mechanicboy
Mechanicboy's Avatar
Liked 153 Times on 120 Posts
Likes Given: 208
Default
From this picture of father and son with the self-made steam engine I would say about 1920-30 years. Fun to fine set of steam engine parts for self-construction. Boiler made of the tin can did someone nothing about think of explosion safety during this period, it's only the cork that served as the safety valve.
Jens Eirik, Bergen in Norway :)
Mechanicboy is offline
Old 10-14-2017, 11:46 AM   #4
JCSteam
Likes Given: 183
Default
That's nothing, I've seen far ropier setups, from modern day. Baked beans tin, and just a filling hole, using a wood screw in some soft brass soldered to the top. Hole in the side for a copper brake pipe, leading to a cylinder and piston which was screwed up tight. So not much room even for that to lift off the face. Scary stuff!!! Even seen an old Mamod boiler blow it's end cap off, this was because the safety valve hadn't been checked and was solid, plus it had suffered from zinc rot, and the end cap was weakened. Blew with some force, and these are only 12-14psi, luckily the guy had just bent down to pick something up when it blew so avoided a nasty burn. Do take care even at low pressures.
JCSteam is offline
Jensen 20G Model Steam Engine Running DIY Steam Hammer JimDobson Photos and Videos 9 09-08-2015 11:41 PM
Beginner Steam Engine and Steam Turbine plans - No machine tools required moya034 Plans 4 10-28-2014 11:14 AM
An Unusual Steam Engine from Live steam magazine Oct 1977 va4ngo A Work In Progress 48 12-03-2012 01:22 AM
Another Scratch Built Steam Engine in Steam Video Steve Photos and Videos 5 12-05-2009 11:17 AM
My First Steam Engine: The Minikin from Steam and Stirling seal killer General Engine Discussion 9 07-16-2009 03:10 PM
