Home Model Engine Machinist > The Tools and Tips > The Shop > Setting up Shop Questions - from an NZ learner
Old 01-16-2018, 05:03 PM   #601
dkwflight
Liked 10 Times on 8 Posts
Default Buying equipment
Hi
Good luck setting up shop.
My personal experience with the cheap chinese lathes does not compare to what others have gone through.
Some have bought and had no trouble.
Mine on the other hand I have come to regard as a "Kit" lathe. Much to try to improve or correct. My 7 x 12 mini is slowly coming around to be a usable lathe. There is a lot of information out there. You tube you cannot always take as gospel. Some on the forums are the same among the truly knowledgeable.
If you buy used you may be buying others worn out or broken stuff. I would try to take a long a knowledgeable person to inspect with you so you will know what the true condition is. Older machines may not have any repair parts available
Some of my experience on you tube
https://www.youtube.com/channel/UC8l...9hjDEgUq3cl4mw
dkwflight is offline
Old 02-01-2018, 08:24 AM   #602
joco-nz
joco-nz's Avatar
Liked 142 Times on 104 Posts
Likes Given: 95
Default
Taking the tank further with lid and the start of the piping, just to show things are still slowing moving forward while being interupted by work committments.
James,
Wellington,
New Zealand
joco-nz is offline
Old 03-16-2018, 08:31 AM   #603
joco-nz
joco-nz's Avatar
Likes Given: 95
Default The on going battle with mess - computer moved to wall mount
In a bid to try and sort some space I thought I would get the computer up on the wall. This might be of use to someone out there. :-)
The mess to be dealt with ...
Slowly winning on that front and making room for next steps.
Stage 1: Cut out some 6mm steel flat and shaped to this triangle. Front plate is clearance hole drilled 6.5mm and the back plate is tapped M6. With three M6 cap screws in place this is should be able to clamp on like a "really strong clampy thing" (alternative phrases failed the census checks)
Hand holding the vertical bracket before welding.
The result all welded up and on the wall. Clamped good and solid as well. The bracket is also painted with rust preventing black paint.
Ta da! Success. With some bench space reclaimed!
James,
Wellington,
New Zealand
joco-nz is offline
2
People Like This
Learner in Houston says hello Naiveambition Introduction 1 03-13-2013 03:37 AM
Setting up a VFD? lazylathe General Engine Discussion 64 04-07-2012 02:31 AM
setting top slide firebird General Engine Discussion 4 12-11-2008 10:38 PM
Setting up my new shop Bogstandard The Break Room 246 09-23-2008 01:21 PM
Setting up shop. Tin Falcon Tips and Tricks 4 12-23-2007 05:18 PM
