Hi all, I decided continue with the water jacket I started so that I could do short demonstrations of the engine running. I just finished the water jacket last night however, the engine would not run with water in the jacket. I don't think it will run with just water cooling without major rework. Unless I have just reassembled in a different position which has more friction. I did make a new displacer rod with a better fit and slot the hole the displacer pillar sits in to allow me to better align things and get rid of the skew when you look from the top.
If not, I think it would probably need some way of insulating between the hot and cold end, possibly a flanged hot cap with insulating material between rather than a screw thread. Also, it would be better with a larger swept volume of displacement piston.
I think I will just leave this one now and learn from the experiences and mistakes I have made!
The next project is to get an old 3 1/2" Gauge Locomotive which I did not build boiler tested and up and running. Then I will do a flame licker based on one of Jan Ridders, an i.c. engine again, based on Jan Ridders pressure controlled two stroke then my main, big project, a 5" gauge sweet pea locomotive. I have to do this as I bought the boiler and castings about 11 years ago!
Here are a few pics of the finished engine anyway.
