Home Model Engine Machinist > Showing Them > Photos and Videos > Engine just finished
Old 07-22-2007, 06:31 AM   #1
Bogstandard
Guest
Posts: n/a
Default Engine just finished
Hi MEM's (Model Engine Machinists),
Here is my own design engine that I have just finished, this is the final vid.
http://www.youtube.com/v/gTuET23TkaI
Built this and wrote up the whole article on another site in just over 2months (that included designing as I went along). I built two in parallel, this one is the basic version, the other will eventually be finished with a load of cosmetic changes to make it look a lot better.
To keep me off the streets I started an elbow engine on thursday, hope to have it finished in a couple of days.
I would have posted a load of pics for you to look at but because of the long winded and roundabout way you are doing it on this site by not being able to post pics direct, I decided against it.
Edited by tattoomike so the video plays in the post window
Old 07-22-2007, 07:50 AM   #2
tattoomike68
Liked 25 Times on 21 Posts
Likes Given: 8
Thats a work of art, I am very impressed.
WOW!
tattoomike68 is offline
Old 07-22-2007, 02:15 PM   #3
1Kenny
Liked 12 Times on 12 Posts
Another WOW.
1Kenny is offline
Old 07-22-2007, 02:25 PM   #4
rake60
rake60's Avatar
Liked 220 Times on 195 Posts
Beautiful work!
Seriously, how many times can THAT happen in one day?
rake60 is offline
Old 07-22-2007, 06:14 PM   #5
Bogstandard
Guest
Posts: n/a
If anyone is interested in building, no plans as yet but a full write up designed for beginners to model engineering, with at least a medium sized lathe and a vertical slide or miller. Only rough sketches but anything that isn't obvious is described how to do it, with the easy way of doing it. You wouldn't believe how easy eccentrics really are if broken down into stages. The crankshaft is made from 13 easily made parts, and assembles into a fully operational crank.
It is a bit long winded in the beginning, explaining basic tooling required and the safety aspect of model engineering, plus a few people giving their two pence (or five cents) worth.
I reckon this engine could easily be built in two to three weeks if you put your mind to it.
It cost me including all the stainless fasteners and silver steel (drill rod), because I use mainly bits from the scrapyard, less than 20 or about $40 to make each engine. If you had to buy the material from a supplier maybe 45-50 or $90-$100.
The only problem for our American friends is that it is all in metric, but no silly decimal places, I designed it to the nearest 0.5mm.
The write up is on here
http://www.paddleducks.co.uk/forum/v...t=2872&start=0
Think you can't do it, well I did and I only have one good arm, the left one, and I'm right handed. So if I can, you could easily achieve this.
finished first engine ever drysdam Finished Projects 15 11-01-2013 05:11 PM
Finished Elbow engine arnoldb Finished Projects 23 02-25-2012 04:12 PM
Elbow Engine Finished Foozer Finished Projects 15 10-01-2011 05:09 AM
finished vacuum engine chizz Finished Projects 13 02-13-2011 03:46 PM
Finished My LTD Stirling Engine Mr VG Finished Projects 6 02-04-2011 04:55 AM
