Home Model Engine Machinist > Showing Them > Photos and Videos > Newbie's first engine.
Old 07-28-2008, 06:25 PM   #11
CrewCab
Liked 32 Times on 32 Posts
Default Re: Newbie's first engine.
Originally Posted by Ian Munro
a warco wmt300 which is one of those combined lathe/milling machines. A bit of a compromise, but space was limited.
very capable machine non the less Ian, I was going to buy the Chester equivalent but happened on a second hand 9 x 20 lathe just before I ordered it, so I then got an X2 mill to keep the lathe company ............. it's a slippery downhill slope though now, .......... there's always more tooling / improvements to buy and do and then things to build with the new tools ............
CC
CrewCab is offline
Old 07-28-2008, 07:40 PM   #12
eleqim
Liked 2 Times on 2 Posts
Aye, there's not enough hours in the day to do all the things I want to, but I guess i've got to wait another 25 years before I can give up the day job
Anyway I have success again! Turns out the piston is triangular, or at least the piston and cylinder certainly aren't circular. If I rotate the piston through 180 degrees it works, rotate it back and it doesn't. I knew the finish was a bit dodgy
Now i'll just have to remember to mark the correct way round, and check if there's a similar issue with the valve.
eleqim is offline
Old 07-28-2008, 07:47 PM   #13
rake60
rake60's Avatar
Liked 220 Times on 195 Posts
Very Well Done Ian!
I have built that engine, TWICE!
No runner yet.
Rick
Seriously, how many times can THAT happen in one day?
rake60 is offline
Old 07-28-2008, 09:17 PM   #14
Twinsquirrel
Twinsquirrel's Avatar
Liked 6 Times on 6 Posts
As for the milling, I bought a warco wmt300 which is one of those combined lathe/milling machines. A bit of a compromise, but space was limited.
Well it certailnly turns out some nice work
Twinsquirrel is offline
Old 07-28-2008, 10:05 PM   #15
Brass_Machine
Brass_Machine's Avatar
Liked 33 Times on 55 Posts
Likes Given: 3
Hey Ian!
Thats a nice looking engine. 1st eh? very well done.
Eric
madmodder - Mod Central
We're all mad here. I'm mad. You're mad.
A still more glorious dawn awaits...-Carl Sagan
Brass_Machine is offline
Old 07-28-2008, 11:44 PM   #16
NickG
Liked 31 Times on 42 Posts
Hello,
That is fantastic for a 1st engine. I have a flame licker based on Jan's design next on my list, however, I've just finished my first stirling engine and that only runs with ice cubes on the cold end and meths burner, it might work if I finish the water jacket off and use cold water completely submersing the displacer cylinder.
Anyway, my point is that to get a flame licker to run on your first attempt is top notch. They are notoriously difficult, I don't really fancy my chances considering my experience with thr stirling! At least with Jan's I know a few people have had success with it though.
As John said, his twin cylinder one looks good and think he has sorted the valve tumbler mechanism now, just waiting for the plans as he reckons he will tweak it such that it should be virtually guaranteed to run so long as it's machined to a good standard with the correct fits etc.
NickG is offline
Old 07-29-2008, 02:15 AM   #17
Mcgyver
Liked 15 Times on 14 Posts
way to go Ian, looks good. Always a great accomplishment to see them run - whats next?
Mcgyver is offline
Old 07-29-2008, 09:25 AM   #18
eleqim
What next? Well probably another Ridders. The problem with going to his site is you think 'Oh! that looks nice to build!', then you look at the next and think 'Oh! that looks nice to build!' and a few minutes later you've got a very long list
Next will probably be one of those lamina flow engines or a LTD stirling because it's not obvious from just looking how they work, but I'll be cheating on these as i've got a couple of those carbon piston glass cylinder air pot thingies. The lamina flow one is looking more tempting at the moment as I haven't worked out a good way to machine true the perspex ring yet.
I quite fancy one on those test-tube marble things, but haven't found a source for ceramic balls yet.
One of Jans IC engine would be nice too
Oh and a conventional stirling and also a poppin flame licker as they make a nice sound.
That should be enough for a while
eleqim is offline
Old 07-29-2008, 09:51 AM   #19
Bogstandard
Guest
Posts: n/a
Ian,
Following a lead by GailInNM I got some of these. Absolutely perfect fit for the 16mm test tubes. They are very lightweight and don't knock the bottom out of the test tubes. They also seem to be indestructable.
http://cgi.ebay.co.uk/Trumark-tracer...3286.m20.l1116
They are so cheap it isn't worth not having any in stock.
Old 07-29-2008, 10:22 AM   #20
eleqim
Thanks for that link John!
I've Just ordered some.
As i've already got some 16mm pyrex test tubes, it looks like the next project's been decided
eleqim is offline
