Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Machine Modifications > Lathe Brake
Old 11-10-2017, 04:44 PM   #21
hanermo3
Liked 6 Times on 5 Posts
Default
I have a different but related observation . fwiw .. if its worth anything.
I got my ac servo spindle drive to run about 10 months ago.
Via timing belts - very good, rigid, wide, powerful timing belts at 1:3 transmission.
The mounts are 30 mm thick tool steel members, and about 30-40 kg in mass.
Namely 24 teeth to 72 teeth, HTD-8 profile, 30 mm wide.
These could transmit about 80 hp of power iirc.
My old spindle motor was 1.5 kW, EU, 220V std ac motor.
New is 2.5 kW 220V ac brushlesss servo motor.
10.000 counts/rev, 3000 rpm.
The servo will fault in 1 ms, on crash, or on estop.
Because the servo faults so fast, and the system is so robust, even a full-on crash does not break anything ... it just faults the servo.
Had 2 faults so far.
I hate pressing estop or stop. The noise is very disconcerting.
Esp. at over 600 rpm, with a 10kg+ 12" 4 jaw chuck + workpieces upto 15 kg.
But it does no damage, despite the World Best Fastest Brake.
The very wide/strong belt absorbs the extra load for the approx 0.1 secs (guesstimate) it takes the servo to fault.
Screwed on chuck, but it has 2 keepers with bolts.
hanermo3 is offline
Brake Cleaner Nick Hulme Mistakes, Blunders and Boo Boos 3 10-10-2016 03:39 PM
Pan Box brake Kiwi_007 General Engine Discussion 0 08-31-2014 02:12 AM
has anyone made a lathe brake and coolant pump? New_Guy Machine Modifications 14 01-04-2011 06:57 AM
Finger Brake d-m A Work In Progress 1 01-16-2010 03:36 AM
Brake/Shear don-tucker Tools 3 12-09-2009 11:59 PM
