Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Machine Modifications > best motor oil
Old 11-17-2017, 12:32 PM   #1
fredepeterson
Default best motor oil
Hi everybody,
what is the best motor oil I can use on my Mazdaspeed protege...
i keep hearing that ams motor oil works great but I wanna know what yall have to say about good oils
fredepeterson is offline
Old 11-17-2017, 09:26 PM   #2
DJP
Liked 71 Times on 62 Posts
Default
My wife has a 94 Miata with 1800 cc engine which may be similar. We only use fully synthetic oil and the brand makes no difference.
If you are serious about this aspect of engine maintenance find an oil analysis lab and buy a case of their sample kits. At each oil change capture enough oil for analysis and watch the wear indicators and oil life remaining. Mostly we throw away good oil by changing too early but this is something that you can watch using oil analysis.
It's probably more important to use premium fuel with engine cleaners included in the blend. That is better maintenance than selecting a brand of synthetic oil, in my opinion.
DJP is offline
10K Pete Likes This
Old 11-18-2017, 12:42 AM   #3
Mechanicboy
Mechanicboy's Avatar
Liked 170 Times on 134 Posts
Likes Given: 229
Default
Viscosity, all Mazda engines and models: 5W-30 or 10W-30.
According to Mazda, "Engine oil viscosity or thickness, has an effect on fuel economy and cold-weather operation (starting and oil flow). Low-viscosity engine oils can provide improved fuel economy and cold-weather performance. But high temperature weather conditions require higher-viscosity engine oils for satisfactory lubrication. When choosing an oil, consider the temperature range your vehicle will operate in before the next oil change." Then select the recommended viscosity from one of the above two grades.
(I am car mechanic )
Jens Eirik, Bergen in Norway :)
Mechanicboy is offline
Old 11-18-2017, 01:41 AM   #4
10K Pete
Liked 112 Times on 101 Posts
Likes Given: 195
Default
deleted useless comment
Just tryin'.....
10K Pete is online now
Old 11-18-2017, 04:39 AM   #5
Hopper
Liked 145 Times on 120 Posts
Likes Given: 132
Default
Newbie's third post and it's to start an oil thread? Sheesh.
Hopper is offline
Old 11-18-2017, 07:19 AM   #6
Mechanicboy
Likes Given: 229
Default
Originally Posted by Hopper View Post
Newbie's third post and ...
I newbie..?
Old 11-18-2017, 07:25 AM   #7
10K Pete
Likes Given: 195
Default
No, not you Jens. The original poster...
Pete
Just tryin'.....
Old 11-18-2017, 07:56 AM   #8
Mechanicboy
Likes Given: 229
Default
Pete
I misunderstand the comments about "Newbie's third post" ,.. thanks
Old 11-18-2017, 07:59 AM   #9
Mechanicboy
Likes Given: 229
Default
Originally Posted by fredepeterson View Post
Hi everybody,
fredepeterson..
Since you're new to the forum, this place is not exactly a car forum. Here we are talking about model engine and machine tools.
And you allready got the info about viscosity for your Mazda car since i am car mechanic in post #3.
Vario BF 20 mill DC motor to 3 phase motor conversion kadora Machine Modifications 3 10-16-2017 02:45 PM
Clutch motor kd0afk Machine Modifications 34 06-18-2014 03:37 PM
1 hp motor project? bikedude987 Tools 4 03-21-2012 10:51 AM
First Motor Gemhund A Work In Progress 8 05-22-2010 03:41 PM
If It Has a Motor I'm Looking! rake60 The Break Room 25 03-16-2010 11:34 PM
