Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Tips and Tricks > Bluing steel part.
Old 07-03-2016, 06:10 PM   #21
Nick Hulme
Liked 67 Times on 50 Posts
Likes Given: 31
Default
(Heat) Oxide colouring is great for delicate parts but doesn't offer the increased wear resistance and oil retention of gun blues making it less suitable for larger, regularly used and handled parts.
W.C. Fields said "You can't cheat an honest man", he should have followed that with "But, you can always find a credulous fool if you need one"
Nick Hulme is offline
Old 07-03-2016, 08:23 PM   #22
Buchanan
Buchanan
Buchanan's Avatar
Liked 145 Times on 46 Posts
Likes Given: 405
Default
Nick
Can one obtain an electric blue or fairly light blue with Gun blue?
Most Gun Blue that I have used over the years gives more of a black blue.
also the blue that I am looking for must be very even, not mottled at all.
any comments would be appreciated.
Buchanan
Buchanan is online now
Old 07-03-2016, 11:40 PM   #23
petertha
Liked 206 Times on 159 Posts
Likes Given: 3
Default
I cant speak for lighter shading aspect but the Clickspring series shows his method & some nice results in terms of evenness & lustre.
http://www.clickspringprojects.com/
petertha is offline
Old 07-04-2016, 11:28 AM   #24
Nick Hulme
Likes Given: 31
Default
Originally Posted by Buchanan View Post
Nick
Buchanan
My point is simply that (Heat) Oxide colouring is great for delicate parts like clock screws which are not often handled but it doesn't offer the increased wear resistance and oil retention of gun blues making it less suitable for larger, regularly used and handled parts, if you used it on a trigger for instance it would begin to wear off with relatively little use.
Unless you recommend (Heat) Oxide blues for firearms and items subject to wear?
Any comments would be appreciated ;-)
- Nick
Old 07-04-2016, 07:59 PM   #25
Buchanan
Buchanan
Buchanan's Avatar
Likes Given: 405
Default
Nick.
I am asking from the clock makers point of view. If gun blue gives oil retention and harder wear and I can obtain the color I am looking for, then I want to use it on clocks. Clock oxide blue would not work on guns as you say. Thjanks.
Buchanan
Old 09-29-2016, 03:48 PM   #26
Toolguy
Liked 12 Times on 7 Posts
Likes Given: 19
Default
Nitre Blue for guns gives a similar iridescent bright blue as the heating. It is only for show pieces normally, as it doesn't hold up to a lot of handling as well as a normal hot blue.
Toolguy is offline
Old 09-30-2016, 01:12 AM   #27
Buchanan
Buchanan
Buchanan's Avatar
Likes Given: 405
Default
Thank you I will give it a try. how do you stop it rusting?
Old 09-30-2016, 02:52 PM   #28
Toolguy
Likes Given: 19
Default
I like to rinse well with hot water, oil and let sit for a day, then wipe off oil and wax with car or furniture wax.
Toolguy is offline
Old 10-04-2016, 01:32 AM   #29
Buchanan
Buchanan
Buchanan's Avatar
Likes Given: 405
Default
What oil do you use. I can get a good blue but when I oil it, the blue goes dull. I use engine oil.Thanks for the feedback.
H. K. Barrows Likes This
Old 10-04-2016, 04:19 PM   #30
Toolguy
Likes Given: 19
Default
I usually use a vegetable based cooking oil for that. Olive, sunflower, canola, etc. The motor oil may have chemicals that attack the blue. Or skip the oil & go to wax.
Toolguy is offline
My first lathe part. Metal_slicer A Work In Progress 9 09-15-2013 07:09 PM
First Ever Part Cogsy A Work In Progress 7 08-21-2012 11:30 PM
copper -> steel conversion factors? Also copper to steel joints? AlfJones Boilers 5 11-21-2011 02:23 PM
Hillman "Steel Works" weldable steel? smfr Metals 2 11-18-2011 07:38 PM
I know there is an engine part in here! Twmaster The Break Room 2 12-19-2009 07:51 AM
