Home Model Engine Machinist > The Tools and Tips > Tips and Tricks > Bluing steel part.
Old 03-07-2016, 01:07 AM   #11
10K Pete
Liked 114 Times on 103 Posts
Likes Given: 198
Default
This is called....... Heat Blue.!!
Used in watches, clocks and guns for a long time. Works especially well
with polished parts.
Not traditionally used for large parts. Small parts and screws.
Pete
Just tryin'.....
10K Pete is offline
Old 03-07-2016, 08:05 AM   #12
ruzzie
ruzzie's Avatar
Liked 39 Times on 33 Posts
Default
I tried out a blackening kit from www.janekits.com.au
ruzzie is offline
xpylonracer Likes This
Old 03-07-2016, 08:43 AM   #13
Pigi_102
Liked 20 Times on 7 Posts
Default
That looks nice !
In any case is a chemical solution, while my way ( well, the way I used, not my way ) does not need anymore than heat.
Pigi
Pigi_102 is offline
Old 03-07-2016, 08:54 AM   #14
Swifty
Swifty's Avatar
Liked 813 Times on 595 Posts
Likes Given: 291
Default
I've been using a chemical blacking kit for years, works very well and the chemicals last for years.
Paul.
Swifty is offline
Old 05-17-2016, 09:03 PM   #15
Scribealine
Liked 2 Times on 2 Posts
Default
A very old method indeed!
Used mainly in watch making in the late 1700's, to blue watch hands and screw heads,
the finish can be enhanced with a fine polish prior to heating, the brass swarf method is always used in horology.
Good to see it.
Scribealine is offline
Old 05-18-2016, 05:22 PM   #16
bmac2
bmac2's Avatar
Liked 555 Times on 400 Posts
Likes Given: 230
Default
Scribealine. You got me. I had to go look that one up.
hoˇrolˇoˇgy
Noun
The study and measurement of time.
The art of making clocks and watches.
Alberta, Canada
bmac2 is offline
Old 05-18-2016, 06:52 PM   #17
petertha
Liked 222 Times on 169 Posts
Likes Given: 4
Default
What is the significance of the brass chips/shavings when torch/heat bluing steel? ie. is there something special about that particular alloy over other choices? Or is brass just what's usually found in a watchmakers chip tray under the lathe?
petertha is offline
Old 05-18-2016, 09:57 PM   #18
Buchanan
Buchanan
Buchanan's Avatar
Liked 167 Times on 49 Posts
Likes Given: 467
Default
The brass serves to conduct and spread the heat in a uniform way, you can spoon or move the brass around on the part to heat one part more than the other to obtain an even color. Clean sand also works. The emphasis is on clean. Any oil or grease will give color variations. A very fine sand paper finish(2500) grit gives a better blue than a mop polish. The type of steel also affects the color Chrome or nickel does not help things and stainless steel is usually hopeless. It is simple to try and if you are not happy with the results it is not to difficult the remove the blue and try again. Every time this happens the polish also improves! The trick is to keep every thing clean and heat slowly. The atmosphere seems to have some effect on the color as well. The old folk always said to use a charcoal fire for the best results. A hot air gun also works as a heat source but I have not found the results to be quite a good as a flame.
An electric muffle also works, you can take the temperature up a few degrees at a time to get the color you like, especially when the part has thick and thin sections.
Buchanan
Buchanan is offline
Old 05-18-2016, 11:34 PM   #19
petertha
Likes Given: 4
Default
Thanks Buchanan. That's kind of why I was asking the question. The blueing temp looks to be just outside the range of my little re-purposed engine bearing removal oven (formerly known as our kitchen mini toaster oven). But assuming you could dial in a specific temp & let it soak there (maybe a conventional heat treating oven in low temp mode) presumably this would be more consistent vs. a torch... would underlying shavings or sand or whatever make any difference if for example you could jut suspend the part on a wire so it was hanging with the exact same atmosphere all around it & no 'bed' contact of any kind?
ps - I've been lurking on your website just fascinated with the clock constructions. Incredible work.
petertha is offline
Old 05-19-2016, 08:40 PM   #20
Buchanan
Buchanan
Buchanan's Avatar
Likes Given: 467
Default
Pertha. yes, I mostly do just that, hang parts (clock) on a thin wire in an oven, The temperatures are obtainable in most cooking devises. Pigi's color chart back a few posts is correct. Screws , I use a block of brass with clearance holes for the thread and heat from below with a small butane torch. Thank you for the compliments . You can see more at www.buchananclocks.com.
Buchanan
Buchanan is offline
H. K. Barrows Likes This
My first lathe part. Metal_slicer A Work In Progress 9 09-15-2013 07:09 PM
First Ever Part Cogsy A Work In Progress 7 08-21-2012 11:30 PM
copper -> steel conversion factors? Also copper to steel joints? AlfJones Boilers 5 11-21-2011 02:23 PM
Hillman "Steel Works" weldable steel? smfr Metals 2 11-18-2011 07:38 PM
I know there is an engine part in here! Twmaster The Break Room 2 12-19-2009 07:51 AM
