Project of the Month built by mayhugh1
Home Model Engine Machinist > HMEM > Introduction > Entering the Hobby
Old 08-16-2017, 02:17 PM   #1
Scrapple
Liked 2 Times on 1 Posts
Default Entering the Hobby
Hi Folks,
Happy to be joining the forum from Delaware, USA. I am entering the hobby and plan to buy equipment soon. Ultimately the goal is to develop the skill level to build the Upshur Horizontal IC farm engine and the Stuart Steam James Coombs engine.
I am leaning toward purchasing a mini lathe and mini mill from Little Machine Shop. With developing enough skill would this equipment be capable of completing these two great projects. Any thoughts are welcome.
Scrapple in Delaware
Scrapple is offline
2
People Like This
Old 08-16-2017, 05:34 PM   #2
oilmac
Liked 3 Times on 2 Posts
Likes Given: 41
Default Entering the hobby.
Scrapple,
It is always an uplift to see folks entering the hobby of model engineering , My thoughts are that to begin with a mini lathe & mini mill , you can build up your skill level (Even if you can build a small and simple engine first, I am not acquint with the upshur engine, but I think the James Coombes is a bit large for the extremely small machines you mention, If you could make contact with model engineers near you, Someone miight mentor you on any machine tool which may appear second hand, to save money, But one must be careful that one is not "buying a pig in a poke"
I always work on the factors of , Can I afford what I am looking towards purchasing, Do I have the space for it, and will the wife/partner be sympathetic/
Another thought is , Is my new machine capable of being man enough & of a size to machine my components
For the general model engineer a lathe of 7" swing is ideal, I always think South Bend or Myford, If you can afford to by all means buy your little mini machines, Even if you eventually purchase bigger , they are always ideal for the occasional weeny component
Many years ago I started my home shop by purchasing an ancient 3&1/2" centre height lathe not in great health But it was a steep learning curve to keep up accuracy.
Many years ago an old engineering works director, councelled me by saying huge is not beautiful , (Unless your passion is saving old iron) As i get older I find myself thinking how right the old boy was, Recently I have started overhauling a little 1950 era lathe I guess it is a step back down memory lane .
oilmac is offline
Old 08-17-2017, 06:14 AM   #3
Cogsy
Cogsy's Avatar
Liked 434 Times on 334 Posts
Likes Given: 414
Default
Welcome to the forum Scrapple. My first IC engine was the Upshur horizontal and I made it on a Chinese 7x14 (same size as LMS sell) with no real problems. The flywheels took a little thought to machine the OD but looking back it should have been easier than I made it be. The Upshur is quite a small engine so I'd guess the mini mill would be fine with it as well.
Having said that, I 'progressed' to a larger lathe within about 18 months of buying the 7x14 as I wanted to make larger projects. I did enjoy the small lathe though, and I kept it even when I upgraded. I can't remember the last time I actually used the thing though...
Al.
______________________
I'd like to be a perfectionist, but I lack the patience...not to mention the skill...
Cogsy is offline
Old 08-17-2017, 07:59 AM   #4
blighty
Liked 47 Times on 40 Posts
Likes Given: 11
Default
welcome to the forum,
I think of it this way........ you can make small parts on a big mill, but you cant make big parts on a small mill. plus you have power and rigidity. do you need power? not really just take small cuts. rigidity? another can of worms. you can discuss the pros and cons on big vs small till the cows come home.
I would say get the biggest machine that will fit in your shed.(with in reason and it wont brake the bank).
blighty is offline
Old 08-17-2017, 04:47 PM   #5
cheepo45
Liked 67 Times on 41 Posts
Likes Given: 27
Default
Welcome to the site!
There will be several model engine builders displaying at the Rough and Tumble museum near Lancaster, PA http://www.roughandtumble.org/ this week.
We have a model building devoted to model engineering. There will be several people from Delaware (myself included), as well as from PA, MD, NJ, etc.
We will be happy to chat with you about engine building. Cheepo45
cheepo45 is offline
Old 08-17-2017, 07:16 PM   #6
Scrapple
Default
Cheepo45,
Sounds like this is a place I should be,Thanx for the tip
Scrapple
Scrapple is offline
New to the Hobby stratysis Introduction 3 02-08-2013 03:59 AM
For my other hobby... mhh The Shop 0 06-21-2012 06:48 PM
My main hobby Hauk The Break Room 7 02-02-2012 07:00 PM
This hobby is like swallowing a fly. 90LX_Notch The Break Room 12 09-28-2011 04:23 AM
My other Hobby Jeff02 The Break Room 6 06-07-2009 09:56 PM
