Project of the Month built by Rustkolector
Home Model Engine Machinist > Building Them > General Engine Discussion > BF20LV Draw bar thread confusion
Old 11-19-2017, 10:31 AM   #31
rodw
Liked 313 Times on 244 Posts
Likes Given: 161
Default
I don't know if it helps but before they sold Optimum, I purchased a Seig SX3 from Hare and Forbes with MT3 spindle and a 1/2" thread. I made a new drawbar. I've never used any 1/2" tooling. I just made sure every MT3 tool I bought had a M12 thread as I'm a metric only guy!
Details of making the drawbar start on page 4 of my "Rod's Aussie Shed" thread. The guys here were very helpful teaching me how to cut a thread.
http://www.homemodelenginemachinist....t=19885&page=4
RodW
Brisbane, Australia
vehiclemods.net.au
rodw is offline
Old 11-19-2017, 06:04 PM   #32
deeferdog
Liked 209 Times on 86 Posts
Likes Given: 46
Default
I finally got off my rear end and made the new draw bar for my BF20LV. The hardest part was cutting the internal M20 x 1.0 pitch internal thread on the ejector, I didn't want to remove the part from the lathe until I was sure the thread was correct. I cheated by making a male threaded plug first that I new was right, then used that to check the internal thread. (I tried to buy a M20 x 1.0 bolt but was told that they are not made). For the bar I used a grade 8.8 M12 bolt, removed the head and threaded it to take 16mm ring for the ejector. I capped it off with a dome nut, loctited and pinned to end. Works well but it took me the best part of the day to make. I'm the same as Rod, a metric only guy, I,m not going to make another for WW! Cheers, Peter
20171115_085415.jpg   20171115_091228.jpg   20171115_091604.jpg   20171115_092941.jpg   20171115_102624.jpg
deeferdog is offline
2
People Like This
Old 11-20-2017, 03:02 AM   #33
marvin_schwartz
Liked 1 Times on 1 Posts
Default
New toys in the garage,
All I need is some younger creatures with bigger muscles to help with getting them on the bench.
I settled for the BF20LV mill and and L160 lathe.
Should have everything I need to nail this draw bad thing once I clean the gunk off them.
Wish me luck.
marvin_schwartz is offline
Old 11-20-2017, 03:45 AM   #34
deeferdog
Likes Given: 46
Default
Marvin, love to see some pics of your shed when you have it all set up. Cheers, Peter.
Old 11-20-2017, 03:46 AM   #35
marvin_schwartz
Default
sure, it'll be a bit squeezy but i think it should work well
Old 11-21-2017, 09:46 AM   #36
miglincit
miglincit's Avatar
Liked 11 Times on 8 Posts
Likes Given: 35
Default
Do not rely on muscles - they will rip in the worst case as will your back
I bought me a motor-crane to handle these parts between floor, machine base and every were else.
Thomas
miglincit is offline
Old 11-22-2017, 03:12 AM   #37
Wizard69
Liked 198 Times on 176 Posts
Default
Thomas
Another option is a chain fall and a place to hang it. But I otherwise totally agree find a way to take the muscles out of the equation. Besides if those young guys drop something you are going to feel real bad. Frankly anything more than 75 pounds can justify a mechanical aid.
Wizard69 is offline
Old 11-22-2017, 01:15 PM   #38
marvin_schwartz
Default
We wound up using a motorcycle hydraulic lifter.
The sort of thing you service motorcycles on.
We were able to walk the units across to the lifter, Pump it up to almost bench height and then slide it over to the bench space.
That way no one needed to lift the units and there was no danger of dropping them.
miglincit Likes This
Old 11-28-2017, 12:50 AM   #39
marvin_schwartz
Default
That was fun,
Got the mill in place, bought some M12 all thread and made an M12 drawbar. Took two attempts the first was over engineered the second was a little more rugged but looks like it will do the job.
Today my first collet chuck turns up. MK3 pheww lucky that's the same as MT3 with a 1/2 thread on the end for a 1/2 draw bar.
OMG now I find out there are two 1/2 threads UNC at 13 TPI and 12 TPI BSW WW. I am learning so much that I never wanted to learn. Looks like it's time to make a third draw bar.
So the adventure continues.
I'll post some pictures soon.
Old 11-28-2017, 01:00 AM   #40
marvin_schwartz
Default
Just before launching into a third draw bar I thought i'd just try it out on the two that I already have.
Popped it onto the 1/2" WW and as suspected half way down the threads started to tighten and jam.
Popped it onto the M12 bar and low and behold it went all the way in, no jamming and held real snug.
The collet holder is a 1/2" 13, well I'll be buttered on both sides.
This looks like it's work well.
How strange.
Thread Equivalents for a Draw Bar joco-nz General Engine Discussion 26 10-08-2016 06:04 PM
Please help!! Silver soldering/brazing confusion Hicube General Engine Discussion 12 03-29-2014 03:04 PM
Big confusion on Elmers 33 cylinder ??!! compressor man General Engine Discussion 12 05-30-2011 04:04 PM
Draw bar question Kermit General Engine Discussion 11 12-20-2009 07:02 PM
confusion !!!! minerva General Engine Discussion 16 10-17-2008 01:48 PM
