Home Model Engine Machinist > The Tools and Tips > The Shop > Setting up Shop Questions - from an NZ learner
Old 01-16-2018, 05:03 PM   #601
dkwflight
Liked 10 Times on 8 Posts
Default Buying equipment
Hi
Good luck setting up shop.
My personal experience with the cheap chinese lathes does not compare to what others have gone through.
Some have bought and had no trouble.
Mine on the other hand I have come to regard as a "Kit" lathe. Much to try to improve or correct. My 7 x 12 mini is slowly coming around to be a usable lathe. There is a lot of information out there. You tube you cannot always take as gospel. Some on the forums are the same among the truly knowledgeable.
If you buy used you may be buying others worn out or broken stuff. I would try to take a long a knowledgeable person to inspect with you so you will know what the true condition is. Older machines may not have any repair parts available
Some of my experience on you tube
https://www.youtube.com/channel/UC8l...9hjDEgUq3cl4mw
dkwflight is offline
Learner in Houston says hello Naiveambition Introduction 1 03-13-2013 03:37 AM
Setting up a VFD? lazylathe General Engine Discussion 64 04-07-2012 02:31 AM
setting top slide firebird General Engine Discussion 4 12-11-2008 10:38 PM
Setting up my new shop Bogstandard The Break Room 246 09-23-2008 01:21 PM
Setting up shop. Tin Falcon Tips and Tricks 4 12-23-2007 05:18 PM
