Project of the Month built by TonyM
Home Model Engine Machinist > Showing Them > A Work In Progress > Astro Skeleton clock.
Old 10-10-2017, 10:41 PM   #51
Buchanan
Buchanan
Buchanan's Avatar
Liked 103 Times on 37 Posts
Likes Given: 334
Default
Yes, I have used Berrilium copper(Dangerous in dust form) and Tungsten copper. The best electrode material I have used is ,to my knowledge Tellurium Copper. It is the best material for copper based electrodes.: Quote: Tellurium Copper's (TelCu) resistance to hydrogen embrittlement combined with its' high electrical and thermal conductivity make it the ideal choice for electrical applications requiring extensive machining, corrosion resistance, or for the production of hot forged products.
The cutting properties of copper are enhanced significantly by creating a copper alloy with the addition of .5% tellurium (C145 Tellurium) which is adapted for use in high-speed automatic screw machines. On a machinability rating scale with 100% equal to free-cutting brass, Copper 145 Tellurium has a machinability rating scale of 85-90%, compared to pure copper which has a machinability rating scale of approximately 20%. The results? Increased efficiency on manual and automatic production lines as well as a significantly longer tool life!
It is a very nice material to machine compared to normal copper and does not cost much more. It is also available in larger sections. Graphite kicks in when you want large electrodes.
Buchanan is offline
kadora Likes This
Old 10-11-2017, 10:26 PM   #52
Buchanan
Buchanan
Buchanan's Avatar
Likes Given: 334
Default
This web page and the videos on it gives a very good overview of the clock. http://www.my-time-machines.net/astro_10-16.htm
Buchanan is offline
2
People Like This
Old 10-12-2017, 01:59 PM   #53
kadora
kadora's Avatar
Liked 281 Times on 111 Posts
Likes Given: 484
Default
Buchanan your clock looks like gearwheel heaven.
All wheels connected and unisono working //communicating?// together.
This masterpiece probably has its own consciousness.
kadora is offline
Help with a clock kiwi2 General Engine Discussion 4 12-31-2016 01:26 PM
Skeleton clock don-tucker The Break Room 2 11-23-2012 09:42 PM
Shop Clock b.lindsey The Break Room 12 03-28-2011 11:32 PM
FERRIS CLOCK max corrigan The Break Room 1 08-04-2009 03:37 PM
The clock at the top Loose nut The Break Room 3 03-20-2008 07:23 AM
