Project of the Month built by SilverSanJuan
Home Model Engine Machinist > Building Them > Plans > PatATE: Asymmetric Transfer and Exhaust in two-stroke engines
Old 07-19-2017, 10:22 AM   #21
Nick Hulme
Liked 57 Times on 42 Posts
Likes Given: 24
Default
If they added a compact, lightweight generator system and a little more wing area to that Ducted Fan (it's not a jet!) battery job to make it a Hybrid I could see it being practical now using battery for takeoff, landing and urban flight.
W.C. Fields said "You can't cheat an honest man", he should have followed that with "But, you can always find a credulous fool if you need one"
Nick Hulme is offline
Old 07-19-2017, 04:26 PM   #22
lohring
Liked 68 Times on 55 Posts
Likes Given: 10
Default
I don't see any large manufacturers putting money into basic piston engine research. The current crop of aircraft piston engines use the best 1940s technology. Turbines have completely replaced piston engines at the higher power levels and in helicopters. They are far superior in reliability and power to weight compared to piston engines. Electric motors should be even more reliable. There are also innovations that will reduce electric motor size and weight. Batteries are the main issue and they are rapidly improving.
Large automobile manufacturers are also starting to put their R&D into electric power and self driving cars. Automobile diesel engines are dead in Europe amid emissions scandals. I expect truck diesels to follow eventually. Several European countries are planning to ban piston engine cars in the near future. China requires automobile manufacturers to build 8% of their future production with electric power.
All that said, I love piston engine technology, especially two strokes. I just don't see a bright future for them. I fondly remember sitting in passenger airplanes while they started those four giant radials. Turbines don't have the same appeal. The quiet of electric motors has no appeal at all. They just get the job done.
Lohring Miller
lohring is offline
Old Yesterday, 04:45 PM   #23
manolis
Liked 38 Times on 28 Posts
Default
Hello all.
The following is quote from Exhaust bridge - Honda 2-Stroke - ThumperTalk
UtahTrailRide:
"Can someone explain to me what the deal is with drilling pistons on the exhaust side. I've heard the CR125 needs the piston drilled but I sure didn't in my last rebuild. Now I'm all paranoid I'm gonna shred something on the hot side."
ChrisLPD:
"OK, this is an old-school 2-stroke engine builder trick Utah,...but that one that works VERY Well! The idea is that the exhaust port bridge in the 2-stroke is a necessary evil. It is the one fault of the efficiency of a tuned 2-stroke engine. Its necessary because it acts as a land for the rings to run against as the slipper piston passes the exhaust port on its stroke to keep the ring compressed. It’s the evil because it’s the absolute hottest part of the motor and the absolute MOST suseptable to cylinder failure or nikasil plating damage for 3 reasons…
1. It is the thinnest section in the combustion chamber and can not dissipate heat. (Imagine taking a torch and heating the entire surface of a sewing needle. If you heat the needle’s eye, the shaft, and the point evenly, which part glows red first? The needle point does because it is the thinnest surface area that can not dissipate the heat).
2. All of the expanding burning hot gasses must pass by it. (Physics of Convection Dynamics)... (Imagine taking that same blow torch and blowing the flame evenly thru the center of your cylinder. It heats up in 360 degree radiation of the heat source. Now focus the flame onto one part of the cylinder. In addition to the heat from thermal radiance, the surface contact point heats up dramatically hotter because of the convection (movement) of the hot expanding gas molecules are bombarding and moving around it. Same thermal convection effect as the hot expanding combustion chamber gasses bombarding and having to move around the exhaust bridge.)
3. In lieu of both of the above critical faults, the exhaust bridge is NOT encompassed by the water jacket to get cooled
Most cylinder failures in a properly jetted and sealed 2-stroke with good fuel and lubrication are on the exhaust bridge because it gets so damned friekin hot. This is especially true of plated cylinders where you first start to see the plating flake off around the exhaust bridge. Drilling the the piston is MASSIVE insurance against this failure from the bridge warping, cracking, or flaking its plated coating. This was done by numerous factory teams and engine builders in the good'ole days before MX had cams, valves, and timing chains. This was when the manufacturers wanted to sale thumpers and pressured the AMA to establish the rules that a thumper was allowed twice the displacement to be "Fair" against the oil burners.
This is how its done...When I set up a 2-stroke, I use set-up dye. An easily removable (wipe-off) acrylic-like paint that you can spray on a part to visually inspect the wear and contact areas during motor building. I spray the dye on the front of the piston (exhaust side) and allow it to dry. I then install the piston on the wrist pin (without the rings) and lightly seat the cylinder down on it.
Once I have the cylinder lined up and seated, I look thru the exhaust port (open exhaust port with no pipe), I cycle the crank (via kick starter) until the bottom ring land passes approx ½ inch above the top of the exhaust port into the compression/combustion chamber. Using an etching tool I lightly trace both the outer left and right sides of the exhaust bridge into the set-up dye on the piston, and then disassemble.
Now with the piston removed I can see where the exhaust port bridge is in the etchings of the dye and I find the center vertical axis between these two etchings. This is the center of the exhaust port bridge. Starting ¾ of an inch below the ring land, I drill two .050 holes vertically (one on top of the other) about ½ inch apart down the center axis between the two vertical left and right marks.
The idea concept is to allow the positive pressure in the crank case (on the pistons downward stroke) to mist just a fine little amount of the cool, raw fuel/air mix onto the exhaust bridge thru the piston holes each time the piston passes the bridge. The cool, raw fuel mix acts as a cooling agent and will surprise you by how much this little trick will drop the temp of the thin little exhaust port. At 6000 RPM’s the critical heat temp on that thin little exhaust bridge is getting misted and cooled with fuel and intake air 100x a second!
Some will say this looses horsepower, I don’t believe so as long as you line the holes correctly and mist the center axis of the bridge and not vent your positive crankcase pressure out of the open exhaust port. Even if does, the loss is very, very, very minimal…but IT WILL SAVE YOUR $400 plated cylinder.
As frdbtr pointed out… This is a commonality of Wiseco recomendation in SOME of their piston kits that most people don’t read. (Some applications do not use a single port exhaust bridge). I am not familiar with the other Wossner brand he named, but wiseco recommends it because IT DOES WORK and their pistons are FORGED instead of cast and do not lose integrity by drilling the holes in the piston wall.
A Note about OEM and cast pistons… The same cooling effect would be benefited from an OEM or any other piston. It’s not often recommended for cast pistons because the “sand-cast” piston will weaken at the metallurgical level when you drill holes in it unless you stress relieve and re-harden it.
Please, please, consider all of the above My Opinion Only,... but as an educated opinion I have been building cast-iron and nikasil 2-stroke motors for 25 years and I have yet to have a cylinder failure of the exhaust bridge since I learned this from World Champion Melvin Cooper (Cooper Company Machine and Racing) building 2-stroke Hydroplane racing engines back in my twenties."
End of Quote.
Quote from http://www.millennium-tech.net/pistonTrouble.php
EXHAUST BRIDGE SEIZURE
Piston seizures can occur at the center exhaust-bridge on a delta-shaped port, or the sub-exhaust bridges on a triple port design. The exhaust bridge is the hottest are of a 2-stroke cylinder and the ring pressure is at its peak because the bridge’s surface area is so small. Seizures happen for many reasons but the most common are 1) Lack of lubrication 2) Too lean jetting or air leak 3) Coolant over-heating 4) Not enough bridge relief 5) No oiling holes in the piston over-lapping the exhaust bridge.
End of Quote
In the PatATE each bridge has not just two tiny holes to cool down it; it has all the fresh cool air / mixture to pass around the bridges to cool down them.
Reasonably, the temperature of the bridges of the PatATE can be about half of the temperature of a conventional 2-stroke exhaust port bridge.
Thanks
Manolis Pattakos
manolis is offline
Old Yesterday, 05:12 PM   #24
Nick Hulme
Likes Given: 24
Default
They're talking real world, man ridden machinery, I don't think it's a big worry with model 2 strokes,
- Nick
Old Today, 06:08 AM   #25
manolis
Default
Hello all.
The PatATE architecture is not restricted in small engines. It fits with small engines, it also fits with normal size and big size engines.
And it seems (theoretically for now) that it solves several crucial problems of the normal size 2-strokes.
Thanks
Manolis Pattakos
manolis is offline
Inlet port open to exhaust - is this normal on some engines ? edholly General Engine Discussion 3 02-16-2014 10:38 PM
Larger 2-Stroke Engines BronxFigs Plans 10 03-22-2013 09:07 PM
2-stroke exhaust tuning? kellyl@westriv.com General Engine Discussion 0 10-31-2012 02:00 AM
2 stroke exhaust port with before needing a bridge digiex-chris General Engine Discussion 8 02-29-2012 04:20 AM
Transfer Punches BobWarfield Tools 16 02-03-2008 09:11 PM
