Project of the Month built by TonyM
Home Model Engine Machinist > The Tools and Tips > Machine Modifications > iGaging EZ-View DRO Plus for my LMS 3900 Mill
Old 07-26-2017, 04:15 PM   #1
SilverSanJuan
Liked 123 Times on 70 Posts
Likes Given: 169
Default iGaging EZ-View DRO Plus for my LMS 3900 Mill
My son gave me a set of iGaging EZ-View DRO Plus for my birthday. I've been using the LMS 3900 Mini-Mill for almost five years on dials alone. Well, that's enough of that.
Here is how the set is delivered.
Since I needed to remove the table and column to install the scales, I took the opportunity to strip down the mill for cleaning and servicing. The next two pictures show the Y-axis installation.
I've installed the X-axis on the back of the table. It is mounted under a 1.25" aluminum angle to protect it from swarf. Also, I needed to extend the scale to the right so that I could mount the reader offset to clear the mill's column base. The LMS 3900 has a tilting column and the pivot protrudes forward. If I mounted the reader in the center of the table it would hit the pivot bracket and reduce my Y-axis travel. The X-axis extension ensures that I have full X-axis travel as well. I see that most folks put this extension on the left side. I chose the right because it will be behind the handwheel and not interfere with benchtop space.
X-axis complete.
The Z-axis was the easiest. I've installed mine on the left side. I removed the 9" ruler and angle that was on the column. The scale was then installed. And, the reader bracket was attached to the long 6mm set screw that held the ruler's pointer. I didn't have any 6mm nuts, so I made one from 7/16" brass hex.
It was a fun project and it took me four evenings to get it all installed. Tonight I will tram the mill column and tidy up the cables to the displays. I do plan on purchasing a TouchDRO bluetooth board for them. I've already installed the app on my tablet and it will make a great display. I'll update that here when I get it.
For now it will be back to my Kozo A3 project.
SilverSanJuan is offline
bazmak Likes This
Old 07-27-2017, 04:30 PM   #2
SilverSanJuan
Likes Given: 169
Default
The displays are mounted on the right side of the mill. The A3 frame is back on the table and getting ready to the have the steam tee opening milled out. I'm very happy with these DROs. So far they've made milling the opening much easier to keep track of the cutters position. No more counting handle turns!
edit: there was supposed to be a picture originally. I just added it.
Last edited by SilverSanJuan; 07-28-2017 at 04:22 PM. Reason: Didn't load picture.
Old 07-28-2017, 01:17 AM   #3
apointofview
apointofview's Avatar
Liked 479 Times on 141 Posts
Likes Given: 4
Default
You did a nice job on the install of those scales.
I just recently installed the yuriy's toys Bluetooth adapter for my scales and I really like it. The functions like the bolt hole circle work great !
Pete
apointofview is offline
SilverSanJuan Likes This
Old 07-28-2017, 04:24 PM   #4
SilverSanJuan
Likes Given: 169
Default
Hi Pete,
Thanks! Yeah, I'm looking forward to getting Yuriy's Bluetooth adapter. I've already loaded the program on my tablet and I'm very impressed with what it can do.
Todd
Old 08-06-2017, 12:15 AM   #5
Kpar
Kpar
Kpar's Avatar
Liked 5 Times on 3 Posts
Default
Hi Todd, Just read your post and headed off to the shed to see if I could do the same on my mill. I'm still learning how to stuff up end mills, lose count on the dials and generally make mistakes. Good fun. Anyway I have a Sieg SX 2.3 and thought a 3 axis DRO would make things a lot easier although most of them in Aussie are a bit beyond my current budget. Maybe the set you installed would fit my needs. What sort of $$ did they cost and where from.
Thanks
Kpar (Keith)
Kpar is offline
Old 08-06-2017, 12:49 AM   #6
SilverSanJuan
Likes Given: 169
Default
Hi Keith,
It is a good time, isn't it? These are from Amazon and the set was US $135.
Todd
Old 08-26-2017, 05:02 AM   #7
Kpar
Kpar
Kpar's Avatar
Default
Hi Todd, Been out of action for a while now back to searching for DRO's. I checked out Amazon where you got yours and none seem to ship to Australia.
Our local supplier "Hare & Forbes" show a kit that looks like the igaging kit so will check them out in a couple of weeks while in Brisbane.
I guess it's the downside of living across the waves with ausie $ and shipping costs. But why would you live anywhere else.
Keith
Kpar is offline
Old 08-26-2017, 06:16 AM   #8
oldboy
Liked 3 Times on 3 Posts
Likes Given: 90
Default
Hi Keith.
Try the WoodKid I think in either South Australia or Victoria, they have the whole range of Igaging gear. I got mine from them ages ago. I working at the moment, when I get home I will get the contact details and let you have them. Mine were from memory around $200Aud. My mill is a Real Bull, X2 copy.
Barry (Oldboy)
oldboy is offline
Old 08-26-2017, 06:21 AM   #9
oldboy
Likes Given: 90
Default
Keith,
Just found some info. www.thewoodkid.com.au. Try this I googled it.
Barry (Oldboy)
oldboy is offline
Old 08-26-2017, 06:52 AM   #10
Kpar
Kpar
Kpar's Avatar
Default
Thanks Barry, Had a quick look and will follow it up. I'd like to get under the $400.00 range
Keith
Kpar is offline
HiTorque Model 3900 Wrist Pin General Engine Discussion 9 08-24-2017 12:10 AM
Igaging DRO product distributor pkastagehand Buy / Sell / Trade / eBay 4 04-30-2014 03:56 PM
The ABS function on iGaging scales dgjessing General Engine Discussion 3 01-17-2012 09:19 PM
Igaging scales on a mini mill BMyers General Engine Discussion 11 04-10-2011 09:32 PM
2D/3D CAD Isometric View DICKEYBIRD General Engine Discussion 25 05-17-2009 07:58 PM
