Project of the Month built by driller1432
Home Model Engine Machinist > Building Them > General Engine Discussion > Gear cutting from scratch
Old 10-31-2017, 06:02 AM   #11
bazmak
BAZMAK
bazmak's Avatar
Liked 1012 Times on 579 Posts
Likes Given: 805
Default
I use R8 on the mill and bought a 50mm face mill with RCT mainly because the
the spigot was 22mm dia and i made a couple of collars for fitting the invalute cutters also 22mm.2 tools for the price of 1
Click image for larger version
bazmak is offline
Old 10-31-2017, 10:29 AM   #12
Hopper
Liked 141 Times on 118 Posts
Likes Given: 132
Default
+1 on get yourself a copy of Ivan Law's book Gearcutting. It's one of the Workshop Practice series and costs about $14 delivered to your door. It has everything in it you need to know.
There are also online calculators that you can use to find out the centre distance of various size pairs of gears in various modules. I dont have a link to one but have used them in the past. Law's book also has charts and calulations for centre distance vs module vs number of teeth etc.
Hopper is offline
bazmak Likes This
Old 11-01-2017, 09:55 PM   #13
john_reese
Liked 4 Times on 4 Posts
Likes Given: 5
Default
If at all possible you should make the cam- crank center distance such that gears of a standard pitch will work. If your center distance does not allow use of a standard pitch Ivan Law's book contains info that lets you make a cutter for any pitch.
john_reese is offline
Old 11-01-2017, 10:39 PM   #14
bazmak
BAZMAK
bazmak's Avatar
Likes Given: 805
Default
As pointed out many times and as i found out Ivan Laws book
is worth its weight in gold.Simple to understand and cheap at $17
Makes the learning curve so much easier
bazmak is offline
Old 11-02-2017, 08:21 AM   #15
Hopper
Likes Given: 132
Default
Under $14 delivered to your door if you get it from Book Depository!
(No connection other than happy customer.)
Hopper is offline
Gear Cutting simister General Engine Discussion 23 02-21-2016 06:25 AM
Gear Cutting lensman57 CNC Machines and Conversions 3 01-24-2012 01:40 AM
Gear cutting again Gordon General Engine Discussion 12 01-28-2011 05:49 PM
Gear cutting hob lugnut Tools 11 07-11-2009 12:34 PM
Gear Cutting dreeves General Engine Discussion 21 01-25-2009 09:23 PM
