Home Model Engine Machinist > The Tools and Tips > Tools > Mini Tapper
Old 04-13-2018, 03:07 PM   #1
bobs7-62steamair
Liked 26 Times on 12 Posts
Default Mini Tapper
Here is the mini tapper I just completed based on plans available online.
Plans call for 3/4" aluminum base 4x6", I used a 1/2" CRS 6x6" base with materials available from local metal monger. Unit works great for #2 and below sized taps.
bobs7-62steamair is offline
7
People Like This
Old 04-14-2018, 12:58 AM   #2
JCSteam
Liked 61 Times on 55 Posts
Likes Given: 343
Default
Link please this may prove useful!
JCSteam is offline
Old 04-15-2018, 01:41 PM   #3
bobs7-62steamair
Default Mini Tapper Plans
Believe I found the Plans in the Download section. Page 1 of the 2 pages of drawings indicate they were provided from "Open Source Tools".
Old 04-15-2018, 02:02 PM   #4
bobs7-62steamair
Default Mini Hand Tapper Plans
Go to Downloads section and search for Mini Hand Tapper and you will find the plans. Located in screen # 10.
Old 04-15-2018, 06:36 PM   #5
Wizard69
Liked 207 Times on 184 Posts
Default
Very nice! Looks like it could handle larger taps than #2.
Have you considered any sort of finish for the CRS! That is rust prevention. Ive been using tool black on some of my stuff. The trouble with tool black is that the protection is minimal.
Wizard69 is offline
Old 04-15-2018, 10:52 PM   #6
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Liked 715 Times on 536 Posts
Likes Given: 77
Default
Here is a very old post of mine that shows a little jig you could make for your tapper, perfect for getting things square to an original hole.
http://www.homemodelenginemachinist....6&postcount=21
If you don't try it, you will never know if you can do it!!
Blogwitch is offline
Old 04-16-2018, 07:45 AM   #7
Cogsy
Cogsy's Avatar
Liked 530 Times on 407 Posts
Likes Given: 529
Default
I've never seen such a thing but it's a great idea. Thanks John!
Al.
______________________
I'd like to be a perfectionist, but I lack the patience...not to mention the skill...
Cogsy is offline
Old 04-16-2018, 10:27 AM   #8
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Likes Given: 77
Default
Thank you Al.
This was from the days I was making batches of the same steam engine, and without it, it would have taken many more hours to achieve what I wanted to do.
I just showed the item without the expanation and it fooled everyone, it was only when I showed the second picture that the light bulb was turned on.
With little jigs like this, if you are doing a lot of tapping, it can make life a lot easier.
I have dozens of little things like this I have made over the years, they really do make things simpler, and well worth the time to make them.
miglincit Likes This
Old 04-16-2018, 06:56 PM   #9
bobs7-62steamair
Default Mini Tapper FU
My shop has very little moisture issues, never experienced any tool rusting. Have large Dehumidifier that does a great job of controlling % humidity, which is currently at 30% RH. During the hot summer muggies here I usually capture about 2 gal/day of moisture, fall & winter much less and during very dry periods the DH never even comes on. DH devices are worth the investment to keep your tooling shinny.
Given my current moisture control I probably won't coat the tapper with anything beyond a light coat of oil yearly.
Yet another self-made hand tapper misfitsailor Tools 1 12-26-2017 06:00 PM
Hand Tapper pricing - Buyer beware David Morrow Tools 5 11-08-2016 08:22 PM
Mini Hand Tapper walnotr Tools 25 07-17-2010 02:05 AM
Hand Tapper Powder keg Tools 60 08-11-2009 06:53 PM
Hand tapper deverett Tools 0 07-30-2009 11:24 AM
