Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Machine Modifications > AL-320 Lathe DRO Upgrade
Old 07-06-2015, 02:44 AM   #1
simister
Liked 29 Times on 26 Posts
Likes Given: 26
Default AL-320 Lathe DRO Upgrade
I am looking to install a DRO on my 320X600 AL-320 lathe (http://www.machineryhouse.com.au/L141).
However, I am not sure if I should get a 3 axis or 2 axis as I am mainly doing small work. I have fitted up 3 axis DRO on my milling machine and now would like to update the lathe.
Any advice please.
john
simister is offline
Old 07-06-2015, 03:05 AM   #2
Cogsy
Cogsy's Avatar
Liked 500 Times on 386 Posts
Likes Given: 490
Default
I got an email from them just this morning with discount codes valid for the next two weeks only - code DV20 gives $20 off if you spend $100 or code DV50 gives $50 off if you spend over $300. I think they're only good for the online site though.
Al.
______________________
I'd like to be a perfectionist, but I lack the patience...not to mention the skill...
Cogsy is offline
Old 07-06-2015, 05:52 PM   #3
XD351
XD351's Avatar
Liked 25 Times on 25 Posts
Default
Depends on what type of 3 axis dro you're looking at , i have the same machine with the 3 axis set up but never bothered to fit the scale to the compound slide as it was going to be a pain in the neck to do so .
The display has only two readouts as you switch between compound slide and saddle X1/X2 axis on the display .
Remember that if you use a milling type readout it wont read diameter or radius like a lathe type dro it will only give you tool travel .
Mine is an Mtech unit from the dro store .
I also have the same unit on my AL50G and wasn't that an adventure fitting that !
Ian
XD351 is online now
Old 07-07-2015, 12:19 AM   #4
simister
Likes Given: 26
Default
Thanks Ian,
I was going to purchase the same unit from the DRO store. Did you only fit the two axis up on both machines or 3 axis on the AL50G. Did you have any trouble doing the two axis on the AL320?
I am not sure if it is an over kill going for the 3 axis? What is your opinion?
simister is offline
Old 07-07-2015, 12:12 PM   #5
rodw
Liked 313 Times on 244 Posts
Likes Given: 161
Default
I've fitted a 2 axis DRO to my AL320G. I went with Ditron and am very happy with the quality. The price was pretty ridiculous.
The cross slide was a bit fiddly but worked out nice.
The long feed was easy, made mounting blocks with a slight angle on them and included a setscrew to level the mounts in case I got the angle wrong. I did not use any of the included mounting hardware.
RodW
Brisbane, Australia
vehiclemods.net.au
rodw is offline
Old 07-07-2015, 07:16 PM   #6
XD351
XD351's Avatar
Default
Originally Posted by simister View Post
Thanks Ian,
The AL320 has the 3 axis display ( really only a two axis unit that lets you switch between 2 scales ) but i never bothered fitting the scale to the compound slide as it is not something i think i will use and not worth the hassle but you may like it and for what the extra cost is may well be worth ordering the the 3 axis unit .
I usually use the carriage to machine close to the length i need then use the dial on the compound slide to nibble away the last bit and if you are having trouble with the type of dials on the machine (metric v imperial etc ) just set up a dial indicator and use that to tell you how far you have moved the compound slide .
Fitting a 3 axis system to the AL50G would be problematic with glass scales as i don't think you can get small enough ones for the compound .
With this lathe i ended up fitting the carriage scale along the front under the apron as the motor makes fitting it behind the bed difficult and i had to make some custom mounts to hang the cross slide scale off the end of the cross slide
Ian .
XD351 is online now
Old 07-07-2015, 07:18 PM   #7
XD351
XD351's Avatar
Default
Wow a triple post ! Damned ipad!
Appreciated if a kind moderator can fix please .
XD351 is online now
Old 07-07-2015, 10:04 PM   #8
canadianhorsepower
canadianhorsepower's Avatar
Liked 296 Times on 236 Posts
Likes Given: 1413
Default
you can delete it yourself
go to edit and delete
cheers
Luc
"if you dont stand for something
you will fall for everything"
canadianhorsepower is offline
Old 07-08-2015, 05:32 AM   #9
XD351
XD351's Avatar
Default
Thanks !
I'm used to another forum that only gives you a limited time to edit anything .
I couldn't do this on my Ipad but once i logged in via the website it all became clear .
Ian.
XD351 is online now
Old 07-08-2015, 06:20 AM   #10
michael-au
michael-au's Avatar
Liked 326 Times on 166 Posts
Likes Given: 782
Default
Any advice please.
john
Hi
I have almost the same lathe as you,
I fitted the two axis DRO to mine, best thing i did
Brand EASON
michael-au is offline
Logan Lathe upgrade mgbrv8 Machine Modifications 3 12-01-2011 02:30 AM
Upgrade tribbil CNC Machines and Conversions 4 11-10-2011 10:33 PM
X2 upgrade update Bill S Machine Modifications 3 02-28-2010 09:09 PM
Polishing using lathe upgrade Divided He ad Machine Modifications 13 12-12-2008 02:10 AM
What upgrade for my computer?? Hal Computer Geek Zone 8 03-10-2008 12:04 AM
