Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Tools > Thinking about making an oxy-hydrogen system for use in the shop.
Old 05-26-2010, 08:14 AM   #1
Kaleb
Senior Member
Kaleb's Avatar
Liked 23 Times on 17 Posts
Default Thinking about making an oxy-hydrogen system for use in the shop.
I have been told by some people at a welding course that an oxy-acetylene system is so much better for silver soldering than my air-LPG torch which I currently use for soldering and annealing copper, but oxy-acetylene is expensive! $300 for the equipment package, and an extra $250-300 for the yearly cylinder hire, and an extra $100-150 or so in gas levy per year to boot! I just can't afford such a system. So I thought, why not use hydrogen instead? I did some reasearch, and I found they use oxy-hydrogen for underwater welding, (It gets up to 2800 degrees celsius!) and I can easily generate both gases from water using electrolysis. Instead of pressurised cylinders, I intend to get the pressure needed in the torch by using a pair of electric pumps. The torch itself will be similar to a regular oxy-acetylene torch. I also intend to make a flame cutting torch at some point as well. I've attached a diagram of the electrolysis cell and torches I intend to make.
If the pictures look funny, just click to enlarge them.
Steadily following the "Up Road"
Kaleb is offline
Old 05-26-2010, 08:45 AM   #2
tel
tel's Avatar
Liked 111 Times on 106 Posts
Default Re: Thinking about making an oxy-hydrogen system for use in the shop.
An ambitious undertaking Kaleb, tho' I suspect that the cost of electricity to generate useful amounts would cost as much, or more than the cost of conventional O/A. Then there is the heat loss you will have - Oxy/Acet generates, from memory, something like 3200C - a 400 loss.
You might be better looking at generating acetylene from calcium carbide - it must be still available as the banana growers ripen bananas with acetylene made in generators. Comes, I am led to believe, in 20kg drums.
Tel
I come from Australia
That's my native land
Where a bird in the bush
Is worth two in the hand
tel is offline
Old 05-26-2010, 11:49 AM   #3
Florian
Liked 24 Times on 24 Posts
Its also possible to use propane and compressed air!
I use an airbrush-compressor (much too small actually) and a 5 kg propane bottle to solder. If i don't need much heat, i just use propane.
When soldering boilers or when i want to heat up very quickly, i open the air valve and then i have more heat. I have even made a new jet with a bigger bore for soldering with air.
Cheers Florian
Florian is offline
Old 05-26-2010, 02:01 PM   #4
shred
Liked 34 Times on 34 Posts
Jewelers have little electrolysis Oxy-Hydrogen setups for doing metals that oxidize poorly, but for some reason they're very expensive and have very small flames. I suspect you'll need a whole lot of H2 production to heat anything reasonably large.
Florian's setup looks interesting-- can you post some more details?
shred is offline
Old 05-26-2010, 03:49 PM   #5
IronHorse
IronHorse's Avatar
Liked 31 Times on 18 Posts
A few years ago I got one of those portable Oxy/Ace units for work on my car. They are convenient because you own the tanks. The tanks are only 14" long, but hold a fair amount of gas. Works perfect for silver soldering with a small tip.
http://www.harborfreight.com/portabl...112&zmap=65818
IronHorse
IronHorse is offline
Old 05-26-2010, 06:09 PM   #6
bucketboy
I've used oxy-hydrogen for underwater welding. I would not recommend its use for anything other than that, hydrogen is very touchy stuff if not treated kindly
Bb
bucketboy is offline
Old 05-26-2010, 10:59 PM   #7
Kaleb
Senior Member
Kaleb's Avatar
IronHorse
That's just what I need, but I'm in Australia.
Kaleb is offline
Old 05-27-2010, 06:28 AM   #8
Florian
I can, but you will have to wait till evening (european time...)
It is actually just a small tube which adds some additional Air to the gas and the air drawn into by the gas. But i guess it could be optimized to draw in more Air... (when using an air jet and placing it on the outside to carry on some more air.
cheers Florian
Florian is offline
Old 05-27-2010, 08:05 AM   #9
bob ward
Liked 19 Times on 19 Posts
From here, http://answers.yahoo.com/question/in...7075209AAyR9sB, I gleaned that at 100% efficiency a 13.2kw power supply will separate water into H2 and O2 at the rate of 1000kg in 24 hours, or 700gm per minute.
A household 240v 10amp circuit provides 2.4kw, which from the above, will electrolize 130gm per minute. There are losses in the system of course, best practice is around 70% efficient, a home made system could be 50% efficient. Even so, at 50% efficiency you will be electrolizing 65gm of water per minute, which should be enough to do fair size silver solder jobs.
I imagine that the cost to build a safe electrolysis system that can absorb a 2.4kw power supply will outweigh the initial purchase cost of an OA system and a few years bottle rent. I'll leave you to work out the cost of your power consumption v buying OA gas.
bob ward is offline
Old 05-27-2010, 08:19 AM   #10
rickharris
Liked 18 Times on 18 Posts
[youtube=425,350]<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/-ceOL83PM24...</param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/-ceOL83PM24&hl=en_GB&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/youtube]
There are commercial systems about.
I am confused
rickharris is offline
thinking mans engine help JackBat General Engine Discussion 9 08-15-2011 10:55 PM
Thinking about a new project cfellows The Break Room 5 06-19-2011 05:54 AM
Thinking small GailInNM Photos and Videos 23 11-22-2008 02:50 PM
Creative Thinking dsquire The Break Room 1 11-14-2008 04:37 PM
Thinking about a radial steamer Brass_Machine Photos and Videos 16 01-05-2008 03:20 PM
