Project of the Month built by Rustkolector
Home Model Engine Machinist > CNC and 3-D Printers > CNC Machines and Conversions > CNC Router for Cutting Steel
Old 11-02-2016, 06:33 AM   #11
weir-smith
Liked 27 Times on 6 Posts
Default
Pat
Today I took some more photos of my machine. I haven't worked how to put a video up as it dosn't to be supported. As I have previously stated, I have plenty of info on the wiring and some of the construction etc
If you would like some help just say so.
Bruce
weir-smith is offline
Old 11-02-2016, 06:41 AM   #12
weir-smith
Default Second Attempt to upload photos
For some reason, I have difficulty with uploading photos. So here goes my second attempt
Old 11-02-2016, 08:23 PM   #13
stragenmitsuko
stragenmitsuko's Avatar
Liked 48 Times on 29 Posts
Likes Given: 7
Default
Bruce , to make a long story short my job requires me to dismantle
and trash various lab grade machines . Incubators , centrifuges , microscopes
biopsy machines , samplers etc etc etc .
A fair amont of these have steppers and ballscrews and lineair
bearings and drivers , power supply's , planetary gearboxes , dc micromotors ....
I really have an overabundance of those . An example are these rotating nut steppers ,
I must have at least 30 of them .
http://www.homemodelenginemachinist....ad.php?t=26124
So for years it's been in the back of my head to use this material
to design and build the "perfect" router . Overdimensioned , over engineered
with every feature included I can possably think of .
As your router is capable of machining steel , it must be very wel designed .
and ridgid . Most routers I've seen won't even machine aluminium .
Hence I'de like to know more about the mechanical construction .
I the upload of the pictures keeps failing , I can pm you with my email
adress ?
Pat
stragenmitsuko is offline
Old 11-03-2016, 11:44 AM   #14
weir-smith
Default
Pat
More than happy to help you out and provide guidance in terms of how I went about my build.
I haven't been able to up load more detailed photos.
If you can provide an email address, I can provide photos, wiring diagrams and some construction drawings.
I have built two other routers for others who had started and were not getting anywhere. Over all, as a project it is not difficult however, you need to decide just what you want to do and then design for it using what is available.
Bruce
CNC Router billscaramu CNC Machines and Conversions 3 01-17-2016 08:39 AM
Cutting a long slot in a fairly thick mild steel plate. Tony Bird Tips and Tricks 12 02-19-2015 12:41 AM
mib 30-20 cnc router sbdtasos CNC Machines and Conversions 3 12-19-2013 02:57 PM
Cutting steel low carbon on X2 pfv Tools 6 01-17-2011 07:47 AM
cutting flywheel out plate steel hinshawracing General Engine Discussion 14 11-03-2010 11:11 PM
