Home Model Engine Machinist > The Tools and Tips > Metals > cooling slots in aluminium problems
Old 10-16-2016, 10:10 PM   #11
Charles Lamont
Liked 116 Times on 81 Posts
Likes Given: 14
Default
Originally Posted by pmdevlin View Post
Hi all,
I have been asked to cut cooling slots in a small cylinder head from a rc plane engine. The slots will create the fins to aid cooling.
I am using 1.5mm cutters on my siege xl mill, and they are 4mm in depth.
Paul
How deep are the slots, and how deep a cut are you taking?
Charles Lamont is offline
Old 10-16-2016, 10:41 PM   #12
bazmak
BAZMAK
bazmak's Avatar
Liked 1094 Times on 622 Posts
Likes Given: 854
Default
If you are using small dia end mills then depth of cut should be less than cutter dia,and speed as fast as you can.Light feed and lots of wd 40 for alum
If you are using a slitting saw then full depth of cut in one pass with speed
as slow as you can.Assuming 1.5w x 4mm dp slots
bazmak is offline
Old 10-16-2016, 11:36 PM   #13
Alchymist
Alchymist's Avatar
Liked 18 Times on 14 Posts
Likes Given: 37
Default
Haven't tried it on an end mill yet, but when using a hole saw on aluminum plate in the drill press - Windex! Yep, the glass cleaner. Just keep spritzing it on as the cut progresses. Rolls the swarf out of the cut, and cools the saw at the same time. Works good when using the sabre (jig?)saw on aluminum also.
Alchymist is offline
Old 10-17-2016, 05:48 PM   #14
llionellis
Default
Tap Magic is available through Amazon But £££££££££
https://www.amazon.co.uk/Tap-Magic-7.../dp/B01M1F533L
llionellis is offline
Old 10-17-2016, 06:54 PM   #15
Toolguy
Liked 12 Times on 7 Posts
Likes Given: 19
Default
In the USA, this is $16.32 US. + shipping for a 16 0z. bottle.
https://www.amazon.co.uk/s/ref=nb_sb...agic+%2320016A
It's 55.27 pounds, look at the link above. Still too much though.
Toolguy is offline
Old 10-17-2016, 09:13 PM   #16
pmdevlin
Liked 3 Times on 3 Posts
Likes Given: 5
Default
Ideally 1.25 to 1.5mm slots, 4 to 5mm deep.
Tonight tried the slitting saws I have for the first time on some scrap, I realised now why they where cheap! Anyway, it was much easier than I had thought, as stated neat and straight. I am using the fine feed for the distance between the slots, after taking out the slack with head locked I can now get the fins pretty much spot on, all the same thickness, so thanks for the info everyone.
Seems to cut better with a medium speed and wd40, going slower resulted in a jam twice. The cut was thicker than the blade, I seem to have a bit of run out caused by cheap saws, or at least the mandrel |(if that's the correct name)
Tapmagic is out at nearly £400!!!! I could buy a second mill for that
so if the depth is 5mm, I have a choice of cutters, one has fine teeth, and rest are much coarser but smaller diameter, does the speed vary according to diameter? The saws say 20000rpm but the machine surely is much less than this?
pmdevlin is offline
Old 10-18-2016, 07:41 AM   #17
Cogsy
Cogsy's Avatar
Liked 529 Times on 406 Posts
Likes Given: 527
Default
It comes up on eBay UK, just search Tap Magic Fluid. Prices were around 20 pounds but I'm in Australia so the shipping might be off.
Al.
______________________
I'd like to be a perfectionist, but I lack the patience...not to mention the skill...
Cogsy is offline
cross slide t slots. trev1 Machine Modifications 19 01-12-2014 10:27 PM
Clamps for T-slots ksor Tools 3 09-10-2013 08:57 PM
Method for fitting Aluminium fins into slots picclock General Engine Discussion 23 09-19-2011 01:08 PM
Tee Slots and clamping JimM Tools 10 03-11-2010 01:59 PM
BV20 Lathe T Slots Omnimill General Engine Discussion 11 11-04-2009 02:06 PM
