Project of the Month built by TonyM
Home Model Engine Machinist > CNC and 3-D Printers > CNC Machines and Conversions > Luck of the Dumpster
Old 12-24-2016, 02:44 AM   #31
DICKEYBIRD
Liked 59 Times on 49 Posts
Default
Nice job Ved; you got that project going very quick! Is that under Arduino control?
"Accuracy is the sum total of your compensating mistakes."
Milton in Tennessee, USA
DICKEYBIRD is offline
peter2uat Likes This
Old 12-24-2016, 01:52 PM   #32
vederstein
Must do dumb things....
vederstein's Avatar
Liked 272 Times on 170 Posts
Likes Given: 80
Default
Yes,
It's running the Arduino as the GRBL motion controller. The bCNC software is the front end (G-code sender to GRBL). When I get some time, I'm going to see if its rigid enough to do light cuts on aluminium.
I finally realized why most CNC routers have the motors to the front, it maximizes the Y-axis travel. As it is now, the router head will pass over the end of the work area making about 1-1/4 inches of travel useless.
I considered making some brackets to gain back that distance, but on reflection I'll leave it. This overhang will allow me to re-square the X-axis when the two Y-axis motors inevitably get out of sync.
They won't go out of sync from the controller: they run off the same step and direction pulse. They'll get out of sync if someone (or thing) bumps the gantry too hard moving one side but not the other.
(I had a picture of the overhang, but there's something wrong with the website and I keep getting an "upload failed" error. Sorry.
...Ved.
vederstein is offline
Old 12-24-2016, 03:24 PM   #33
DICKEYBIRD
Default
Originally Posted by vederstein View Post
Yes, It's running the Arduino as the GRBL motion controller. The bCNC software is the front end (G-code sender to GRBL). When I get some time, I'm going to see if its rigid enough to do light cuts on aluminium.
That's amazing stuff to me; it was hard enough for me to learn how to use Mach. Seeing what you fellows that really understand computers are able to accomplish never ceases to amaze me.
I think it will do better than you think in aluminum. You'll just have to get your feeds & speeds adjusted to suit your machine & not worry about the blinding speeds & metal hogging feats that seem to obsess everyone. After all, the goal is to make cool stuff, not to fill up one's shop with chips in 5 minutes!
Old 12-24-2016, 08:06 PM   #34
vederstein
vederstein's Avatar
Likes Given: 80
Default
Thanks for the praise, but I'm not really doing anything novel. I'm standing on the shoulders of those that actually wrote and maintain the GRBL and bCNC projects. I just read up on it and put the components together. Those people in the open source community are the real innovators on this project.
I am an industrial machine designer/engineer, so guess I have a technical leg up than most when it comes to machine integration, but I'm no programmer.
As for the chips, I can attest at this time it makes a hell of a lot of wood dust.
Thanks,
...Ved.
Old 02-16-2017, 12:08 PM   #35
peter2uat
Liked 4 Times on 2 Posts
Likes Given: 62
Default
Great idea, will copy this as soon as my interest in the 3D-printer thing diminishes ;-)
I love seeing you all doing impossible (for me) things!
Peter
peter2uat is offline
Bad timing, bad valve, bad luck ghart3 Engines From Castings 7 10-26-2011 07:03 PM
Luck and a camera Cedge The Break Room 4 05-02-2010 03:00 PM
Some guys have all the luck SignalFailure The Shop 8 01-03-2008 01:21 PM
