Project of the Month built by Ghosty
Home Model Engine Machinist > CNC > CNC Machines and Conversions > Luck of the Dumpster
Old 12-03-2016, 08:50 PM   #21
vederstein
Project of the Month Loser!
vederstein's Avatar
Liked 247 Times on 159 Posts
Likes Given: 65
Default
Continuing on with the spindle mount...
The clamp ring is kind of a mini-project in itself given the number of steps it takes to make this thing. Also, I've stated in previous threads: SLITTING SAWS SCARE THE HELL OUT OF ME!!!!!
Note the upper screws are far too long. They're just what I have laying around. I'll get the correct length when I get to the hardware store.
Onto the pictures....
vederstein is offline
2
People Like This
Old 12-04-2016, 02:34 PM   #22
DICKEYBIRD
Liked 53 Times on 43 Posts
Default
Nice work Ved; you're gettin' closer & closer to making CNC routed chips every day! I know what you mean about mini-projects; it seems like every step of my projects lately involves the making (or buying) of a new tool or fixture.
Is that a 3 jaw chuck on your mill? How'd you accomplish that?
I got tired of running to the screw supply house every few weeks a couple years ago so I bought a crap-load of the longest ones of each size that were threaded all the way to the head. I made this thing I call the "Screw Chopper" from a cheap HF angle grinder. I use it all the time & it sure saves gas & time going out for screws!
"Accuracy is the sum total of your compensating mistakes."
Milton in Tennessee, USA
DICKEYBIRD is offline
4
People Like This
Old 12-04-2016, 09:24 PM   #23
vederstein
vederstein's Avatar
Likes Given: 65
Default
I have a 2" three jaw Bison chuck. The end is threaded 1/2-20. I made an arbor for it so I can use a 5/8" R-8 collet to mount it. My mill is a round column mill/drill. So sometimes I'm starved for Z-axis clearance. When in a jam I use the chuck. If I just move the head up or down I lose my X and Y positioning.
As for this job, my mill head was a bit too high and I didn't have enough Z-axis to reach the ring centerline so I used the Bison to gain an extra 1-1/2" of Z-axis.
...Ved.
Old 12-10-2016, 09:13 PM   #24
vederstein
vederstein's Avatar
Likes Given: 65
Default
Continuing on with the router build:
I had come to decision time. It may sound odd, but I had to consider what side is the front.
If you go to the Probotix website, the CNC routers they have for sale (they have dual Y-axis motors like the one I'm building does) have the motors facing the operator. I don't know why they chose this, but it has the advantage of running less length of cable. On the other hand it places the motors in a position where they could get bumped. In my research, the most I've seen have the motors in the same orientation as the Probotix: at the front.
I decided to put my motors on at the rear of the machine. I think this will help keep crud and debris out of the moving components since most of the milling will be done towards the front where it's easier for the operator to access.
So I re-oriented the machine. I also moved the X-axis gantry to gain an extra three inches in Y-Axis travel.
I also think this will make the operator's side less cluttered after I install the electrical connectors and E-stop button.
...Ved.
2
People Like This
Old 12-10-2016, 09:16 PM   #25
vederstein
vederstein's Avatar
Likes Given: 65
Default
After re-orienting the gantry, it was time to install the drag chain.
Again, this was done without any plans, I just placed the chains where it seems logical and went at it, making brackets as I went.
I'm getting excited that I may have this thing running under its own power soon!!!
...Ved.
2
People Like This
Old 12-11-2016, 02:49 PM   #26
DICKEYBIRD
Default
Lookin' good Ved; it won't be long now! That drag chain looks great; did you find a reasonably priced source for it? I saw somewhere that a fellow 3d printed his own snap-together links. Must be nice!
Looking at your bridge, can you still add a couple triangulated braces in the Y-direction to reduce flexing on heavy cuts? I guess it would help in the X-direction as well but that'd mean at least 2 extra rail trucks and would reduce the travel.
Anyhoo, make sure & post up some video when the time comes!
peter2uat Likes This
Old 12-11-2016, 03:57 PM   #27
vederstein
vederstein's Avatar
Likes Given: 65
Default
Thanks,
The drag chain came from an e-bay store: http://www.ebay.com/itm/322232081490...%3AMEBIDX%3AIT
Hell, most of the components I've had to buy for this project came from ebay.
If necessary, I can add more support, but I want to see how it cuts before putting more weight into this thing. The ball screw slides are quite heavy and at this point, I don't even know how I'm going to get the machine off the saw horses it's sitting on.
So, does anyone know how much deflection is typical for a CNC router? Obviously less is better, but there must be some acceptable level or these things would be 2000# blocks on cast iron.
...Ved.
Old 12-11-2016, 05:07 PM   #28
DICKEYBIRD
Default
Great price on the drag chain, thanks for the link!
All you need for a bunch of added rigidity is to put a diagonal aluminum brace between each y-axis vertical member & the cross-beam. Doesn't need to be big & heavy, just enough to do the job. With those big honking steppers, you don't have to worry about a little more weight.
Old 12-18-2016, 10:08 PM   #29
vederstein
vederstein's Avatar
Likes Given: 65
Default
Continuing on with the router build....
Cables! Cables! Cables! More Cables!!!!!
I figured out that thus far I've had to make 76 solder connections and I really haven't started the home sensor and E-stop wiring yet.
I partially disassembled the machine to modify a panel through which the electrical connectors are attached. The material is too thick for the connecters, so I added a pocket.
I was able to actually get the thing powered up. I made three wiring mistakes which I corrected at the control box.
I can move the machine in manual mode and it will take G-codes individually, but the BCNC software won't run a proper cutting program. I think it's because BCNC spoon feeds GRBL way too fast. Has anyone had the same issue and know how to fix it?
That's all for now....
...Ved.
2
People Like This
Old 12-23-2016, 07:21 PM   #30
vederstein
vederstein's Avatar
Likes Given: 65
Default
I was able to do some initial cuts today. After a little bit of a learning curve and inverting my Y-axis, I present the following video....
I still need to receive switches for the homing sensors and the E-stop. Sometimes shipping just takes a while.
...Ved.
3
People Like This
Bad timing, bad valve, bad luck ghart3 Engines From Castings 7 10-26-2011 07:03 PM
Luck and a camera Cedge The Break Room 4 05-02-2010 03:00 PM
Some guys have all the luck SignalFailure The Shop 8 01-03-2008 01:21 PM
