Project of the Month built by Stefan-K
Home Model Engine Machinist > The Tools and Tips > Machine Modifications > CNC x2 Mill
Thread Tools Display Modes
Old 12-20-2016, 03:53 AM   #131
Rndmann9
Liked 14 Times on 10 Posts
Default
Gees not sure when I'm going to see my shop again. Got a week off for Christmas then work is going to be nuts for a while. I'm right there from finishing this little exercise too. Might be my saving grace to get me away from my computer and not going crazy. I hate doing hospitals, they are one complicated beast. Well I'll get some hot lead therapy in before the craziness at least. Got the new one a nice set of glasses finally.
Rndmann9 is offline
Old 12-20-2016, 08:27 AM   #132
Foozer
Liked 48 Times on 47 Posts
Default
Been tinkering with Arduino, NES game pad, 20x4 LCD, NEMA 17 stepper and a 3" rotary table using CFellows bit of code - -
laststep = round(stepsDiv * lastPosition);
nextstep = round(stepsDiv * currentPosition);
divSteps = abs(nextstep - laststep);
In a different wrapper - Divisions and Degrees - -
Making the adapter to mount the stepper to the little table has been a case of "Really?" Had this hunk of 2 1/4 round . . .
Lets see - one each AA109 lathe, bore a hole 3" inches deep?
Cut away all that is not needed on the outside?
Subtractive Process Defined - More of the stock goes to the trash bin than is left . . . But its Fun - -
Week or so - should be done - - Have no idea what I'll do with it - Just seemed like something to do - Run a Rotary using a NES Game pad . . .
Robert
"Nothing is more irritating than that which exposes the pedigree of ideas"----Lord Acton----
Foozer is offline
Old 12-22-2016, 12:21 AM   #133
Foozer
Default
Had to quasi-assembly and check it out - And, well it works - Have 2 menu choices, one for divisions, one for degrees - Running it through its paces and so far seems not to skip a beat. NES Controllers are dangerous, can get way to many button choices . . .
#define btn_A 254 // Select Divisions
#define btn_B 253 // Select Degrees
#define btn_Start 247 // Enable Stepper
#define btn_Select 251 // Disable Stepper
#define btn_Up 239 // Not used
#define btn_Down 223 // Not Used
#define btn_Left 191 // Jog Forward One Division (CW)
#define btn_Right 127 // Jog Back One Division (CCW)
#define btn_A_Up 238 // Increase Divisions (also Disables Stepper)
#define btn_A_Down 222 // Decrease Divisions (also Disables Stepper)
#define btn_A_Right 126 // Future use - Increase Divisions Step Rate
#define btn_A_Left 190 // Future Use - Decrease Divisions Step Rate
#define btn_B_Up 237 // Increase Degrees by One Degree (also Disables Stepper)
#define btn_B_Down 221 // Decrease Degrees by One Degree (also Disables Stepper)
#define btn_B_Right 125 // Future Use - Increase Degrees Step Rate
#define btn_B_Left 189 // Future Use - Decrease Degrees Step Rate
#define btn_Menu 243 // Return to main menu
Still can't get the LCD screen to show in pic - - -
Now to find a little project box and package it up
What I'll do with it? Haven't a clue . . .
Foozer is offline
Lathe and Mill plans (home made making mini lathe and mill) alihureiby Plans 14 03-22-2013 12:32 PM
Mill-rite mill rebush Tools 4 05-11-2012 11:58 PM
Tramming a small mill (Sherline mill) ttrikalin Tips and Tricks 9 11-22-2009 06:58 PM
