Home Model Engine Machinist > Building Them > Plans > LSx Engine w/ 1" bore
Old 05-19-2015, 12:19 AM   #51
bigmellon
Liked 28 Times on 15 Posts
Likes Given: 3
Default
Working on the matching cylinder heads now... But there were some earlier attempts. I was able to get the bore spacing back closer to stock and have to rebuild the heads again. Not bad though! I love the details and thinking about watching this thing turn over.
Click image for larger version
bigmellon is offline
4
People Like This
Old 05-19-2015, 02:00 PM   #52
Metal_slicer
Metal_slicer's Avatar
Liked 28 Times on 22 Posts
Likes Given: 7
Default
Looks awesome. it is going to be nice.
Sherline 5400 Mill (CNC)
HF 7x10 Mini Lathe
Visual Mill 6.0
Mach3
Metal_slicer is offline
Old 05-19-2015, 09:17 PM   #53
Metal_slicer
Likes Given: 7
Default
Now you need to print the intake manifold. About how long did it taker to print the block and heads?
HF 7x10 Mini Lathe
Visual Mill 6.0
Mach3
Old 05-20-2015, 03:14 PM   #54
bigmellon
Likes Given: 3
Default
I think the block took around 12 hours. The heads were around 7 hours each if I am not mistaken.
Old 06-22-2015, 03:56 PM   #55
bigmellon
Likes Given: 3
Default
Oh, I have been bad lately, neglecting my little project!!
I have been researching different casting methods. Lost wax/pla seems to be the best, but I still like the idea of doing core sand molds to pour blocks from! Maybe I am weird...
I am planning to send out for a water clear SLA of the block. I will then inject colored epoxy through the oiling system to highlight the oil pathways. I may even fill the water jackets with colored epoxy as well. This way, you could literally look through the block to see how these LS engines are plumbed. I may make the cam and crank from steel, add brass bearings, and try to make the engine spin over at low rpm for a desk top model... Sounds fun to me anyway.
Well, back to revising my cylinder head design...
Old 06-22-2015, 07:11 PM   #56
dieselpilot
Liked 109 Times on 98 Posts
Likes Given: 3
Default
Oops, posted in the wrong thread. I'm following along just watching. The SW models look good. I'd like to build a BMW six like a S38B38 one day.
Greg
dieselpilot is offline
Old 06-23-2015, 07:26 PM   #57
donw1948
Likes Given: 10
Default Any recent progress?
I admire the work you done so far ! I hope you find time to do more.
donw1948 is offline
Old 07-06-2015, 01:24 AM   #58
bigmellon
Likes Given: 3
Default
Oh, there is time My progress seems to be going in spurts on this one, but it is a fun mental exercise
Old 12-07-2015, 02:37 AM   #59
bigmellon
Likes Given: 3
Default
Hey all,
Been too long since I have posted anything, so here goes! Attached are pictures of the modeled LS7 crank, connecting rods, and pistons.
Name:	Screen Shot 2015-12-06 at 9.32.31 PM.jpg
Name:	Screen Shot 2015-12-06 at 9.32.58 PM.jpg
I have printed a few of these off in ABS plastic. Really looking forward to trying lost PLA on this model to see how the castings turn out. I have water jackets int he model and they print fairly well with the ABS. I am hoping I can get that level of detail using vacuum assist casting.
2
People Like This
Old 12-08-2015, 10:33 PM   #60
bigmellon
Likes Given: 3
Default
Name:	Screen Shot 2015-12-08 at 5.18.30 PM.jpg
Suitable boiler plans for a 1 1/2" bore Stationary Engine ned100 Boilers 22 11-03-2015 11:39 AM
Horizontal IC Engine 5/8" Bore cfellows A Work In Progress 79 02-23-2015 04:06 PM
Engine bore/stroke ratios MarkB General Engine Discussion 11 05-29-2014 01:01 PM
Boiler feed pump (cylinder bore v pump bore) question syrtismajor General Engine Discussion 2 09-28-2011 06:39 PM
Reaming a 1/8" bore to about 2 1/2" deep DickDastardly40 Tools 9 11-28-2008 08:38 AM
