Project of the Month built by apointofview
Home Model Engine Machinist > Building Them > Plans > LSx Engine w/ 1" bore
Thread Tools Display Modes
Old 05-03-2015, 09:48 PM   #41
bigmellon
Liked 27 Times on 14 Posts
Likes Given: 3
Default
I have been working on the cam and cam bearings... Conventional cams have different size bearings with the largest bearing in the front of the engine. This likely eases installation...
My question for the group - Would you machine the cam bearings the same diameter for this small scale? It seems that it may be hard to install the bearings unless I stagger the diameters slightly.
bigmellon is offline
Old 05-13-2015, 03:36 PM   #42
bigmellon
Likes Given: 3
Default
Well boys... 12 hours from now I should be able to handle the first draft of the LS7 block. Functional coolant and oiling systems... all holes are center drilled to be tapped. The block isn't 100% quite yet, but getting close.
Click image for larger version
Name:	Screen Shot 2015-05-13 at 11.34.13 AM.jpg
Old 05-14-2015, 02:00 PM   #43
bigmellon
Likes Given: 3
Default
And here it is... I am actually surprised the print came out so well. For the number of undercuts on the part, it's not too shabby!
2
People Like This
Old 05-14-2015, 05:14 PM   #44
Metal_slicer
Metal_slicer's Avatar
Liked 28 Times on 22 Posts
Likes Given: 7
Default
Very nice. Is the print qualiy good enough for aluminum casting?. It looks like a wax pattern.
Sherline 5400 Mill (CNC)
HF 7x10 Mini Lathe
Visual Mill 6.0
Mach3
Metal_slicer is offline
Old 05-14-2015, 09:22 PM   #45
bigmellon
Likes Given: 3
Default
This one was made form ABS. I could print in PLA and do lost PLA casting when the design is finished. I am still watching videos from Aonemarine on this and learning about his casting method with vacuum assist.
Sure is nice to have the model in hand to reference.
Old 05-15-2015, 12:51 AM   #46
Metal_slicer
Likes Given: 7
Default
It looks so cool. It must be satisfying to hold the design in your hand and to be able to look at it in the real world.
HF 7x10 Mini Lathe
Visual Mill 6.0
Mach3
Old 05-15-2015, 01:49 AM   #47
bigmellon
Likes Given: 3
Default
It sure is! Even when you know all the dimensions, it is always a wonder to hold it in your hands. I was surprised at how "large" this block is. The block is 5.500" long.
Old 05-15-2015, 05:09 AM   #48
aonemarine
aonemarine's Avatar
Liked 185 Times on 141 Posts
Likes Given: 29
Default
5.5" long = large roflmao I am truely blessed.....LOL seriously though, before you try casting it let me know. There are some things that just wont happen with the lost pla casting..
aonemarine is offline
Old 05-16-2015, 05:02 PM   #49
bigmellon
Likes Given: 3
Default
You are a funny man Aone...
After reading back through my last post, I guess I could have phrased things a little differently.
Old 05-16-2015, 06:42 PM   #50
aonemarine
aonemarine's Avatar
Likes Given: 29
Default
I try to be......but sometimes people just dont get my dry sense of humor....
Suitable boiler plans for a 1 1/2" bore Stationary Engine ned100 Boilers 22 11-03-2015 11:39 AM
Horizontal IC Engine 5/8" Bore cfellows A Work In Progress 79 02-23-2015 04:06 PM
Engine bore/stroke ratios MarkB Questions and Answers 11 05-29-2014 01:01 PM
Boiler feed pump (cylinder bore v pump bore) question syrtismajor Questions and Answers 2 09-28-2011 06:39 PM
Reaming a 1/8" bore to about 2 1/2" deep DickDastardly40 Tools 9 11-28-2008 08:38 AM
