Project of the Month built by Rustkolector
Home Model Engine Machinist > Building Them > Team Builds > TB2 build Elmer's #46 Comber - back from the dead
Old 04-03-2015, 10:22 PM   #11
GailInNM
GailInNM's Avatar
Liked 287 Times on 239 Posts
Likes Given: 111
Default
Sweat equity in getting it running counts!!
Gail in NM
Gail in New Mexico, USA
I would like to be the kind of person my dog thinks I am.
GailInNM is offline
Old 04-04-2015, 01:39 AM   #12
vascon2196
vascon2196's Avatar
Liked 285 Times on 195 Posts
Likes Given: 82
Default
Great job bringing it to life!
Chris
"A good craftsman never blames his tools"
vascon2196 is offline
Old 01-01-2017, 12:22 AM   #13
kvom
kvom's Avatar
Liked 605 Times on 483 Posts
Likes Given: 283
Default
At last year's CF and NAMES, the engine never came to life. Since this year CF is dedicated to Elmer's Engines, I made another try. Needs 40 psi, but she turns.
kvom is offline
2
People Like This
Old 01-01-2017, 08:42 AM   #14
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Liked 698 Times on 520 Posts
Likes Given: 73
Default
Hi K,
I really do love the Elmers engines, they usually work like it says on the tin and can be built by almost anyone.
I notice that on both your vids there is a 'screeching' noise, is this coming from the engine or somewhere else in your shop?
If it is from the engine, it sounds as if there is a slight misalignment problem somewhere that may be causing some drag which requires overcoming by using more pressure.
Nice one!!
If you don't try it, you will never know if you can do it!!
Blogwitch is offline
Old 01-01-2017, 01:54 PM   #15
kvom
kvom's Avatar
Likes Given: 283
Default
That screech is from a smoke alarm on the ceiling 13' up. Replacing the battery is a PITA, but it's a backup since the alarm is on a power line too. Plus the shop has a second alarm.
kvom is offline
Old 01-01-2017, 03:41 PM   #16
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Likes Given: 73
Default
Glad it isn't the engine K, if it was it was it definitely needed a good dose of looking at.
As it is, it most probably only needs an hour or two running in.
Old 01-18-2017, 09:23 PM   #17
kvom
kvom's Avatar
Likes Given: 283
Default
I took the Comber to Cabin Fever, as Elmer's Engines are a theme of the show. I ran it periodically until it threw a wheel (cotter pin on roller axle came loose). One of the exhibitors at a nearby table had a double size Comber that ran very well at slow speed. I noticed that his forks didn't extend past the edge of the cam, hence less friction. Seemed like a good idea to try, as it also makes assembly easier.
I also decided to do as Gail and use ball bearings as the rollers. Way back in the early days I'd bought a package of such bearings in anticipation of the Kerzel team build that never got underway, and even better managed to find it. The bearings are .25" in diameter, so equal to the roller. Shaft diameter is 1/8" and width is .100": perfect.
I made the first test fork and installed it, at which point I realized that the forks are needed to keep the rollers aligned to the cam. Not sure how the other guy did his, but at least one of the forks needs to extend past the cam edge. So for the second fork I took the old one, drilled the roller axle hole out to 1/8 and used some 1/8 drill rod as an axle. The drill rod is a press fit to the bearing, so no retainer is needed; the fork keeps the bearing centered in the slot and the axle secure. I actually milled down the inside arm of the fork enough so that the cylinders could be squeezed into the cam.
The engine now runs a lot better after firing it up. Previously needed 40 PSI and ran very fast. Now at 20 PSI it can run much slower, probably around 200 RPM.
I measured the valve diameter (.499) and the diameter of the bearing (.505), so the air consumption is pretty easy to understand. To improve this I could remake the bearing with a tighter tolerance, but for now I'm going to let it be. If I decide to go to NAMES by air, I can take it and the Coventry as carryon.
kvom is offline
Raising DRs from the dead modela Finished Projects 6 05-29-2012 05:22 PM
dead LCD monitor gbritnell Software and Programming 10 03-19-2012 12:26 AM
Dead mill Sshire General Engine Discussion 8 12-27-2011 04:19 PM
Back from the dead - TB2 parts Brass_Machine Team Builds 1 12-16-2010 06:10 PM
Dead center and filing Hobgobbln General Engine Discussion 8 03-16-2010 02:45 PM
