Project of the Month built by Rustkolector
Home Model Engine Machinist > CNC and 3-D Printers > CNC Machines and Conversions > Windows shopping for 3-D printer.
Old 10-04-2015, 07:36 PM   #121
Tin Falcon
Tin Falcon's Avatar
Liked 814 Times on 647 Posts
Likes Given: 18
Default
Thanks for the link.
Interesting.
The old wanting champagne on a sodapop budget.
Want a $ 1200 dollar printer for $500-$600 but have probably spent$ 550 in time looking searching and waiting .
truthfully may end up building from scratch. Want something faster than most what I have seen and Ideally an 8x 12 build platform. I have been looking for deals on a flashforge . will see.
the lulzbots look nice a prusa with a more stable frame.
And I have considered a prusa kit and build a frame/ enclosure around it.
Also have considered rebuilding upgrading the SD4 but not until i have something else running.
Let us know how you make out with the new shop addition.
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
littlelocos Likes This
Old 10-05-2015, 10:39 PM   #122
littlelocos
Littlelocos Model Engrg
Liked 32 Times on 20 Posts
Likes Given: 59
Default
Tin,
This one fits your size bill and could be machined from aluminum on your equipment rather than spending $$$ on the full kit. Appropriately named: Hackerbot 2.0.
https://opensourcehardware.it/en/61-hackerbot.html
https://github.com/OSHW/HackerBot/releases/tag/2.0
You may need the free Solidworks reader software to read the CAD files, but it should be all there.
Enjoy,
Todd.
littlelocos is offline
Old 10-06-2015, 10:59 AM   #123
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
Default
Thanks todd I downloaded and extracted the files and downloaded sw file manager. Have been looking at the design.
Old 10-06-2015, 10:07 PM   #124
ultibots
Liked 1 Times on 1 Posts
Default Great support, quality & quick shipping...
Originally Posted by littlelocos View Post
Hey Tin,
Have you checked these guys out?
They also have aluminum corner upgrades and a lot of options for each kit.
http://www.ultibots.com/mini-kossel-...-printer-beta/
http://www.ultibots.com/kossel-250-v...-diy-kit-beta/
Look like some pretty-well thought out kits with some very nice hardware.
Enjoy,
Todd.
(My "new" demo unit should be here Wed.)
Todd & All -
Thanks for the kind words and interest in www.UltiBots.com. We are a family owned business providing 3D Printer kits, components, and filament. Great support, product quality, and quick shipping are our goals.
As an incentive to try UltiBots, I have enabled coupon code HMEM for 5% off your next order. The coupon is valid through October 14th.
Please call 772-257 one thousand or email sales )at( ulti bots.com with any questions.
Happy Printing!
Brad Norman
Owner - UltiBots
ultibots is offline
Old 10-08-2015, 02:40 AM   #125
littlelocos
Likes Given: 59
Default
I received the Lulzbot Mini yesterday and printed a couple of rough test prints. Much better having switched to the finer settings. Material is 3mm Taulman N-Vent running at 230C, 60C bed, 180microns, 50mm/sec, w/ 20%fill. Of course, printing a 2"-tall Yoshi. Print time was 90 minutes.
It's hard to believe that it will print as tight as 50micron and up to 275mm/sec. We'll have to try that another time (and not at the same time, I'm sure.)
Looks like we had some trouble with the supporting material under that left arm.
So far, I'm very happy with this one.
Enjoy!
Todd.
p.s The eBay seller, jtrevino, apparently still has some of these and is selling about 1 every day or two. I'm not sure where these may have come from, possibly returns or ?? The build date on mine is June 30, 2015. I will be replacing the PEI bed layer ($25) and have adjusted the coordination between the Z-axis drive motors.
larry1 Likes This
Old 10-11-2015, 06:47 PM   #126
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
Default
This interesting a bit tempting even.
Thinking of putting my name on the list. 15mm frame a little Light ?
Core xy design inexpensive kit. Hmm http://fusebox3d.onlinewebshop.net/fusebox-3d-printer/
tin
Old 10-12-2015, 01:35 AM   #127
Draw-Tech
Draw-Tech's Avatar
Liked 84 Times on 46 Posts
Likes Given: 65
Default 3 D Printer
Hi Brian
Bought a Rostock Max 2 Kit, can't say enough about how good this machine is. Building the kit helps to fix problems, that might take a tech. I have been printing now for about 6 mos. I have learned to scale the parts so close you can push a bearing into a seat. I intend to print my knucklehead motor. The build on this machine is over 10" in diameter, and 14" high. Kit $999.00 worth every penny. The support of this machine is like no other that I have ever encountered. I have attached a sample of a print, in it's just printed state and after several hours of making it pretty.
Jack
Draw-Tech
Draw-Tech is offline
larry1 Likes This
Old 12-03-2015, 10:43 PM   #128
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
Default Clone
And yet another option to consider. As many of you know the early Makerbots were released open source. As such the replicator 2 has been manufactured under several names by several manufacturers.And at various price points. Flashforge being the most solid of the clones and CTC being a cheaper version. This well known design is once again re released in kit form by Folger Tech
$349 US for a single extruder $379 for dual extruders
Again this is a kit and assembly is required it also features a ramps arduino controler and marlin firmware not the mighty board and replicator G
So this this would run with RH and slicer or cura.
http://folgertech.com/products/folge...3d-printer-kit
Another option to think about.
larry1 Likes This
Old 12-04-2015, 04:17 AM   #129
aonemarine
aonemarine's Avatar
Liked 187 Times on 143 Posts
Likes Given: 29
Default
you know...I think I might actually order one. Thats a really good price...
aonemarine is offline
Old 02-19-2016, 08:15 PM   #130
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
Default
For better or not I just ordered one of these.
Folger Tech Prusa 2020
Now that I have had a 3d printer for about a year and a half and read about the many upgrades that can be made and installing modding changing firmware I am ready for some nuts bolts and bits and bytes work. But I really am not liking the tear my only working printer apart to rebuild it better approach.
I am already planning upgrades for the kit I purchased aluminum block bearing holders for the bed and have the parts for a full ED3 ready to go .I see myself adding aluminum braces to the tower. I see this kit as an inexpensive learning lab. Then I will decide if the next step is a scratch build or rebuild around the Solidoodle 4 .
Selling High Res SLA DLP 3D Printer - UK EddieV Buy / Sell / Trade / eBay 0 09-26-2013 09:03 AM
Recycling a laser printer chucketn General Engine Discussion 10 09-10-2013 08:41 AM
My overengineered 3d printer student_Machinist Finished Projects 16 12-20-2012 04:01 AM
Cheap, DIY 3D printer rleete The Break Room 1 02-06-2010 07:26 PM
Windows 7 and Alibre ver 11.2 Andy_B The Break Room 3 11-22-2009 02:16 PM
