Project of the Month built by driller1432
Home Model Engine Machinist > CNC and 3-D Printers > CNC Machines and Conversions > Windows shopping for 3-D printer.
Old 08-23-2014, 06:20 PM   #101
Tin Falcon
Tin Falcon's Avatar
Liked 814 Times on 647 Posts
Likes Given: 18
Default
CHP posted this link in my something to doodle with thread.
http://www.structur3d.io/#discov3ry
This is touted as a major discovery.
In fact people have been exploring and building and trying to sell a variety of 3-d printers.
Form fill filament is just one technology.
another technology is using an injet printer to print a binder on plaster powder one layer at a time then dipping the part in Ca or epoxy to finish it.
SLS selective laser sintering uses powdered metal as a base and a high power laser melts the selected are together.
STL stereo lithography uses a laser to selectively cure a liquid polymer. Or turn the monomer into a polymer. though selective heating.
the paste extrusion method above is another viable option.
there is company in England selling a 3D printer for decorating cakes and other food.
I see a future with refrigerated 3d printers and chilled bed plates for printing chocolate and Ice cream.
I see numerous articles of 3-d printed organs and body parts still experimental but there could be a future of 3d printed organs for transplant.
NASA and GE are using the technologies to make metal parts for the aerospace industry.
The one caravat is sometimes it is hard to separate the true breakthroughs from the dreams the hype and the gadgets.
So more than one technology competing and complementing,like I said earlier in the toddler stage. What will it look like when it grows up. will it thrive or fail.
IMHO a lot of R & D is going into this. So an ever changing landscape I think 3-d pringing will be a big part of manufacturing in the future. And like computers the applications are near endless.
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 09-06-2014, 12:34 PM   #102
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
Default
Well folks with over a hundred posts to this thread and over 6000 reads I decided to keep this thread alive.
And I intend to post information pertinent to home shop 3d printing and info that may help someone choose or use a 3d printer.
One of the really nice add ons or features of the better 3d printers is stand alone printing. the bad news is this not a feature to be found on a printer with a price tag below about $700 . Some printers that are open source can easily be upgraded with off the shelf add ons to give a small led display and an sd card slot.
The other advantage to stand alone is that motion control benefits form a dedicated computer. laptops and even desktop computers that are on the net and multitasking can interrupt motion control.
So the good news is that With inexpensive off the shelf components I can add stand alone printing /remote control/remote /monitoring to my 3d printer .
So the list of needed items:
1) raspberry Pi model B or B+
1) case for pi
1) 5v usb power supply with usb to micro usb power cable
1) TV or monitor with HDMI input 1) Hdmi Cable
1) Wireless or usb keyboard and mouse
1) powered USB HUb
1) class 10 (recommended) SD card or micro card depending on rpi model
1) web cam
1) wireless dongle or wired Ethernet connection for the printer.
1) last but not least a copy of the octoprint program to run things open source software. http://octoprint.org/
The great news is I have most of the things on the above list.
FYI It seems this software will work on a beagle bones black as well but the Pi seems more popular and easier to set up and I own a raspberry pi that is not getting much use.
Old 09-06-2014, 06:59 PM   #103
RonGinger
RonGinger's Avatar
Liked 124 Times on 93 Posts
Likes Given: 7
Default
Using a Pi is not really standalone, its just using different computer. Most of the printer board based on arduino boards can have a graphics pannel added to make it a real standalone. The graphics boards are under $20 and should just plug into the arduino, unless other wires or connectors interfere. Then you just load an SD card with the file, plug that into the board and go.
RAMPS is one of the most common control boards. Here was the first link google found for a full kit, with the graphics card. I'm sure some digging will find the graphics card alone.
RonGinger is offline
Old 09-07-2014, 12:32 PM   #104
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
Default
Back to what can I make with a 3d printer?
here is a cool answer . How a bout one of these. The below photo a scale model of a Ducati 1199
Lots more photos here:
http://www.redicubricks.com/3d-print...the-ultimaker/
The other question I get is how strong are the parts .
The answer depends on the material used to print
ABS not particularly strong but is stable withstands heats fairly well for a thermal plastic
PLA a lot stronger but can warp in the heat of a hot car in summer and will biodegrade in the heat moisture of a composter.
In a nutshell the early popular materials are not the best for real functional parts.
colorfab XT was developed to change this.
made with Eastman Amphora 3D Polymer it is a tough ,strong material that is temperature resistant chemical resistance, fda aproved for food contact styrene and PBA free and low odor in processing.
With all the material options available nylons, elostomers' cabon fiber ....
yes one can print functional parts.
For anyone wanting to build this model the STL files are HERE https://www.youmagine.com/designs/du...sign-documents
larry1 Likes This
Old 09-07-2014, 01:20 PM   #105
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
Default
I have the SD4 not sure what board it uses do not think it is ramps. I have heard there is actually an sd slot in there not sure if there is a connector for a display and controller. Have not taken the cover off to look .
I suppose I could use the pi and access it with a cheap wifi tablet.
Old 10-06-2014, 10:36 PM   #106
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
Default
Sept 28 went to the http://enablingthefuture.org/ 3d printed Prosthetic conference amazing things happening. Anyone with skills can join, a 3d printer helpful. Met many great folks and drooled on the Ultimakers on display.
Dremel has anounced a 3d printer. http://3dprinter.dremel.com/ it is a relabel/ remix of the flash forge dreamer. These will be sold though home depot and amazon to start with.
Old 10-07-2014, 09:07 PM   #107
AussieJimG
Liked 124 Times on 116 Posts
Likes Given: 4
Default
It just keeps getting better Tin, thank you.
Jim
Engineering: Combining art & science to create artifacts from dreams (Henry Petroski)
AussieJimG is offline
Old 11-01-2014, 12:58 PM   #108
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
Default
OK the newest or one of the newest models from Soliidoodle is the "PRESS" ok as in printing press but I took print shop in high school and know a printing press makes an impression by pressing the ink covered letters or the print roller against the paper. This machine forms a 3D image by extuding or squirting molten plastic first on the print bed then on the previous layer. SOO should this not be called the Squirt Hmm just sayin'.
And I am still pondering my own build.
And I found this e-bay seller http://stores.ebay.com/folgertechnol..._pgn=2&_ipg=48
That I may start picking up parts from.
And another answer to the question what practical use does a 3D printer have look here. A guy using it to make Printed circuit boards.
http://www.3ders.org/articles/201410...uit-board.html
Old 11-05-2014, 11:54 PM   #109
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
Default
```So how big is 3d printing right now?
big enough for Army Technology Magazine to dedicate an entire issue to it.
http://usarmy.vo.llnwd.net/e2/c/downloads/352196.pdf
Old 01-10-2015, 12:58 AM   #110
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
Default 3d printing Singapore history
Thought gus might like this. and others as well.
http://www.3ders.org//articles/20141...3d-prints.html
Selling High Res SLA DLP 3D Printer - UK EddieV Buy / Sell / Trade / eBay 0 09-26-2013 09:03 AM
Recycling a laser printer chucketn General Engine Discussion 10 09-10-2013 08:41 AM
My overengineered 3d printer student_Machinist Finished Projects 16 12-20-2012 04:01 AM
Cheap, DIY 3D printer rleete The Break Room 1 02-06-2010 07:26 PM
Windows 7 and Alibre ver 11.2 Andy_B The Break Room 3 11-22-2009 02:16 PM
