Project of the Month built by Rustkolector
Home Model Engine Machinist > CNC and 3-D Printers > CNC Machines and Conversions > Enco (Rong Fu RF30) Mill/Drill Conversion
Old 12-14-2013, 02:01 AM   #61
stevehuckss396
Senior Member
stevehuckss396's Avatar
Liked 948 Times on 639 Posts
Likes Given: 8
Default
Originally Posted by cfellows View Post
Just a quick update. The DB25 cable was delivered a couple of days ago. I got the motors, the Gecko controller, cables and the power supply all hooked up. Loaded up Mach3 and got everything configured. The steppers all respond and move correctly to the Mach3 commands. Even loaded up the G-Code file to print my name and ran it. Unfortunately, I still haven't received my X & Y timing belts (Aarrgghh!). So, even though the motors spin, the table doesn't move... Wish I'd ordered the belts sooner. Now that the conversion is virtually done, the waiting is killing me!
Chuck
Chuck! thats great to hear.
Quick note: when you get the belts on remember that the arrow keys on the keyboard are which way the tool is supposed to move, not the table. That means when you hit the left arrow the table should move right. When you hit the arrow to move toward you, the table should move away from you. When you arrow left and the table moves right its the same as the tool moving left.
stevehuckss396 is offline
Old 12-14-2013, 04:06 AM   #62
cfellows
cfellows's Avatar
Liked 759 Times on 487 Posts
Likes Given: 3
Default
Thanks, Steve, I had to double check, but turns out I did have it right. I can tell from the direction the motors are turning which way the table will move.
Chuck
cfellows is offline
Old 12-17-2013, 09:30 PM   #63
cfellows
cfellows's Avatar
Likes Given: 3
Default
Got the belts today. Here's a picture of the first job...
Video is still uploading to Youtube... will post the link later.
Chuck
cfellows is offline
canadianhorsepower Likes This
Old 12-17-2013, 09:44 PM   #64
kuhncw
Liked 62 Times on 60 Posts
Likes Given: 9
Default
Chuck, that looks great. You are going to love this thing.
Chuck Kuhn
kuhncw is offline
Old 12-17-2013, 11:27 PM   #65
cfellows
cfellows's Avatar
Likes Given: 3
Default
Thanks, Chuck, here's the video...
Chuck
cfellows is offline
Old 12-18-2013, 12:03 AM   #66
barnesrickw
Liked 124 Times on 106 Posts
Likes Given: 4
Default
That is very smooth. Very nice work once again.
barnesrickw is offline
Old 12-18-2013, 12:31 AM   #67
stevehuckss396
Senior Member
Likes Given: 8
Default
How freakin cool is that!
Do my name now!!
Old 12-18-2013, 06:15 AM   #68
cfellows
cfellows's Avatar
Likes Given: 3
Default
Thanks, Steve, Rick. I think I ruined the only felt tip pen I have!
So, I want to do some profile cutting in 1/4" aluminum plate (I'm guessing it's 6061) using a 1/8" Kyocera, 2 flute solid carbide bit. My milling spindle will only do about 2500 RPM. How fast should I feed the work and what depth of cut would be best? I've currently the feed rate set at 12 inches per minute. I've looked at several web pages and they start talking about surface feet per minute, inches per tooth, and other terms that I just don't understand.
Chuck
cfellows is offline
Old 12-18-2013, 01:17 PM   #69
barnesrickw
Likes Given: 4
Default
Feed rate stuff? I only remember some of it from running CNC 13(?) years ago. I'll bet you have a good enough feel and ear for it from all the milling you have done. I only did it in one material so I only had to change RPM and FPM based on cutter diameter.
Old 12-18-2013, 01:57 PM   #70
LSEW
Liked 10 Times on 7 Posts
Default
Chuck, the aluminum profiling I have done was with a 2 flute carbide bit at 1800 rpm. At the time that was the max spindle rpm. I cut .008 deep at about 1/3 the tool width. The problem you are going to run into is the tool will try to gum up(I assume you aren't running a coolant). Stand by with a can of WD-40.
With Mach it's difficult to stop and start again, but if your tool gums up you will probably break it. The low RPM helps to keep the tool clean because of less heat generation.
maury
LSEW is offline
Planning a drill press conversion, any thoughts? Kaleb Tools 23 04-02-2016 07:54 PM
Enco GL-30B mill/drill belts, manual? RAB Tools 5 09-18-2013 02:21 AM
SOLD Enco mill/drill SOLD gbritnell Buy / Sell / Trade / eBay 5 11-12-2011 03:37 PM
Enco's 115 drill bit sets milotrain General Engine Discussion 19 02-15-2011 10:39 PM
RF30 (Round post drill/mill mods BillTodd Machine Modifications 5 05-10-2010 10:11 PM
