Project of the Month built by edholly
Home Model Engine Machinist > The Tools and Tips > Machine Modifications > myford mg12 cylindrical grinder
Old 12-15-2016, 10:26 AM   #21
blighty
Liked 40 Times on 35 Posts
Likes Given: 11
Default
dont you just love ebay!
when i got this thing, it didn't come with a tail stock. the guy had a look, but couldn't find it. never mind i'll see if a can get one. HOW RUDDY MUCH! this was the only one i found..... all yours for £1950 here is the link http://www.jubileemactools.com/websi...EW!-p-446.html
two weeks ago i thought i would have another look, one on ebay came up £70 all in
blighty is offline
bazmak Likes This
Old 12-17-2016, 09:47 PM   #22
blighty
Likes Given: 11
Default
Jim,
as it took me 3 years to get the top on, i'm not taking it off again. so this is the best i can do :-)
you can get to the bolt by the door on the front.
blighty is offline
Old 12-17-2016, 09:54 PM   #23
blighty
Likes Given: 11
Default
the spring guides under the table.
blighty is offline
Old 12-17-2016, 10:08 PM   #24
blighty
Likes Given: 11
Default
the feet with the wheels on,
the bit on the bottom is made from 1 1/2 angle (i think, i should measure it)
that tucks under the base, the wheel have been made to stick out 6mm below this. when you screw the levelling screws down you can push them under the base. then get the ratchet strap and tighten them together. then wind the levelling screws back up.
be careful when pushing it around, the mg-12 is VERY top heavy. wouldn't take much for it to go over.
20161215_214135_001.jpg   20161215_214150.jpg   20161215_214206.jpg   20161215_214216.jpg
blighty is offline
H. K. Barrows Likes This
Old 12-31-2016, 02:32 AM   #25
blighty
Likes Given: 11
Default
been playing in the shed again
the beds of OD grinder come in two parts. there is the main part that is fixed and goes up and down the main bed. the other table (the one you can see) sits on top of the fixed one, but can pivot in the middle. when i was cleaning this part up it seemed a bit stiff. thought best do it proper like and take it to bits. the pic shows it was full of this rubber grindings/dust stuff.
the work head was no better. second pic... top right is where the work head is.
20161209_160802.jpg   20161214_213211.jpg   20161214_213225.jpg   20161214_213249.jpg
blighty is offline
Old 12-31-2016, 02:36 AM   #26
blighty
Likes Given: 11
Default
separating the work head bits, found more rubber gunk.
blighty is offline
Old 12-31-2016, 02:42 AM   #27
blighty
Likes Given: 11
Default
random pics of the rest.
work head drive housing.
coolant tank.
guides that sit between the bed and table.
20161217_132237.jpg   20161222_122745.jpg   20161224_115319.jpg   20161224_141031.jpg
blighty is offline
Old 12-31-2016, 02:50 AM   #28
blighty
Likes Given: 11
Default
all done.... ish. need to sort out the main coolant tank and pump. and give the bottom half a lick of paint.
20161229_204454.jpg   20161229_204522.jpg   20161229_204546.jpg   20161229_204600.jpg   20161229_204741.jpg
20161229_204756.jpg   20161229_204822.jpg   20161229_205039.jpg   20161229_205115.jpg   20161229_205250.jpg
blighty is offline
Old 12-31-2016, 05:20 AM   #29
bazmak
BAZMAK
Liked 709 Times on 413 Posts
Likes Given: 594
Default
I did not realize Myford made industrial machines.Nice refurb job well done
I wonder how much profit you could make on that,if you can get out of the shed
bazmak is offline
Old 03-25-2017, 03:51 PM   #30
MachineTom
Senior Member
MachineTom's Avatar
Liked 117 Times on 88 Posts
Likes Given: 7
Default
All depends what a willing buyer will pay a willing seller. lOL
The market for cylindrical​ grinder s is very small. While CNC cylindrical grinders are still in use, manual machines are no longer made.
My Wheels don't slow me down
MachineTom is offline
The "Beijing Deckel": Musings About a T&C Grinder from the Lowly HF Grinder BobWarfield Machine Modifications 8 04-10-2016 07:00 AM
Cylindrical Grinding (Germany) MuellerNick General Engine Discussion 7 10-23-2012 05:53 AM
Cylindrical Grinding MachineTom General Engine Discussion 6 08-20-2012 08:28 PM
Cylindrical Workpiece Holding Antman General Engine Discussion 7 12-11-2011 11:31 PM
Cylindrical grinding mhh Tools 5 12-27-2010 12:01 PM
