Project of the Month built by driller1432
Home Model Engine Machinist > CNC and 3-D Printers > CNC Machines and Conversions > Getting started in cnc
Old 03-16-2014, 12:49 PM   #21
aonemarine
aonemarine's Avatar
Liked 187 Times on 143 Posts
Likes Given: 29
Default
they do make a 40k rpm air spindle for it, id probably use a roto zip or something i guess....I think its a fair price (i can afford it any way)
$2700.00
aonemarine is offline
Old 03-16-2014, 01:06 PM   #22
Tin Falcon
Tin Falcon's Avatar
Liked 814 Times on 647 Posts
Likes Given: 18
Default
Can i run a 1/16" ball end mil at that low a speed? cutting aluminum...
I think many of us tend to run conservative speeds and feeds in the home shop.
I remember in USAF Machining school the lathe section we were required to calculate rpm for aluminum IIRC it was a 1" round bar and the calculated answer was something well over a thousand rpm . Then the instructor tell us to use something like 540 rpm.
The calculated rpm for a 1" aluminium bar on LMS calulator is 1910 I do not think I ever run that fast. And my shaper would likely be jumping if I used recommend speeds for aluminum. So conservative speeds are fine . but still leaves the question of what is too slow?
So can you run an 1/8 ball endmill at 2 k probably . Would faster be better ? yes.
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 03-16-2014, 05:50 PM   #23
aonemarine
aonemarine's Avatar
Likes Given: 29
Default
Well just got back from looking at the mill. Left a deposit and will be picking it up on saturday. Its very very nice all most new and hasnt seen much use at all.
Tin sounds like your shaper runs like mine...Maybe we should have a shaper drag race LOL
Old 03-16-2014, 10:51 PM   #24
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
Default
IIRC the syl america x-2 go for the same or more than what you are paying.
Good luck with the new machine.
Old 03-17-2014, 12:17 AM   #25
Dave Sohlstrom
Liked 29 Times on 25 Posts
Default
You will soon discover that the limited Z travel will be a pain. Also taking the machine out of tram and then returning it to tram is a real pain on these mills. Does it have ball screw on all axis. I expect that they are still using the rack and pinion for the Z axis.
There are better machines out there. Tormach 770 is a very nice machine. It does cost more money, but you get what you pay for.
2k RPM for a 1/16' ball end mill is way slow. I run 1/16 at 18,000 on an high speed spindle on my machine.
Dave Sohlstrom is offline
Old 03-17-2014, 12:32 AM   #26
aonemarine
aonemarine's Avatar
Likes Given: 29
Default
Dave, that tormach 770 is $8000.00. I'm getting this machine for $2700. It's all I can afford right now, but I am thinking I may put a ballscrew on the z inside the column instead of having it driving the quill.
I think this machine has a vfd on the spindle, and it does have the jog pendant, one shot lube, cooling, bench/stand, and some tooling. Haven't seen it run yet and won't know if it does until I get it home.
But I think its a great start at a good price.
Old 09-21-2014, 03:47 PM   #27
cnewb
Liked 2 Times on 1 Posts
Default
Air Turbine ??
I'm looking at one I saw at IMTS show in Chicago last week. Made by airturbinetools dot com.
Model 730MX 40K RPM ( ER11 - 1/4" COLLET ) my choice. Model # 70002, I think.
Less than $800. My use will be light duty, so I think quality of this one is excellent.
Held one in my hand, virtually no vibration, just a little whine.
cnewb is offline
Old 01-23-2016, 08:22 PM   #28
chrsbrbnk
Liked 20 Times on 19 Posts
Default
getting back to it yes you can run a .06 end mill at 2000 rpm just slow the feed down accordingly some thing towards 1 inch a min. and say soluble oil as a coolant cutting fluid I haven't really found the " you get what you pay for" actually works that well as a rule
chrsbrbnk is offline
Old 01-31-2016, 06:40 AM   #29
geo
Liked 1 Times on 1 Posts
Likes Given: 5
Default
Are the tormachs any good
geo is offline
Started on my furnace ! ksor Home Foundry & Casting Projects 10 08-10-2012 05:56 PM
how to get the bollaero 18 started deetzy General Engine Discussion 13 04-10-2012 10:27 PM
Started my first engine willburrrr2003 A Work In Progress 8 06-24-2011 05:20 PM
Trying to get started! cshamilto Introduction 8 01-31-2010 10:18 PM
Getting started enginebob Tools 3 10-02-2009 12:58 AM
