Project of the Month built by driller1432
Home Model Engine Machinist > Building Them > Plans > Wobbly engine plan for critique.
Old 01-03-2012, 10:44 PM   #11
bearcar1
Senior Member
Liked 43 Times on 43 Posts
Default Re: Wobbly engine plan for critique.
Say Mike, now it looks like you are cooking with gas. Do you have dimensions down yet? I ran across a packet brand new miniature ball bearings that I would be ideal for this engine. I'll have to find them again in the tool chest and verify what size they are. Keep up the good work.
Jim B.
bearcar1 is offline
Old 11-16-2016, 02:52 PM   #12
bikerbob
Liked 1 Times on 1 Posts
Default Oscillator
Originally Posted by Thegsey View Post
As promised, attached are the revised plans. I have tried to take in as much of your ideas as possible. Please let me know what you think.
Thank you very much!
Mike
I am rather new to steam engines; but your design looks like something I could accomplish. I have downloaded the revised drawings but see that a number of the compounds lack dimensions. Is there a set of dimensioned drawings?
If so could you email a set to the address below
Bikerbob@magma Dot Ca
Thank you for your attention
Robert Wager
bikerbob is offline
Old 01-04-2017, 02:12 AM   #13
ssaxer
Default Wobbler
We build a similar engine in the Intro to Manufacturing Operations class here at the university that I work at. We have found that hole placement is critical for best performance. As the spacing of the holes gets closer together the hole size has to get smaller but the cylinder has less distance to travel. If the holes are too close the pressure needs to increase (because the holes have gotten smaller) and you need a flywheel with a large moment of inertia (I) to get you over the dead spot at the top and bottom. As to flywheels a larger diameter, thinner one is better than fat small one as there are less issues with overhung support.You can calculate "I" this way:
Mass moment of inertia = (1/2) * m * r^2
m = density * (thickness * Pi * r^2 )
So I = (Pi/2) * density * t * r^4
It is also important tho make sure that you guide the piston all the up and down in the cylinder. If yo let it come too far out of the cylinder it will rock and you will cause excess friction.
ssaxer is offline
Wobbly Engine Plan - Finished, I think? Thegsey Plans 6 07-08-2017 08:29 AM
Photos of a completed engine from Ray Hasbrouck's #3 engine plan slkride Photos and Videos 5 04-03-2011 01:07 AM
plan+engine casting marine engine marcocnc Buy / Sell / Trade / eBay 3 10-03-2009 01:31 AM
Critique my setup Bill S General Engine Discussion 7 02-03-2009 04:40 PM
Please critique my workbench design dan s General Engine Discussion 8 11-12-2008 04:40 AM
