Project of the Month built by driller1432
Home Model Engine Machinist > Building Them > General Engine Discussion > What can I scrounge smallish metal gears out of?
Old 11-18-2010, 10:38 PM   #1
Kaleb
Senior Member
Kaleb's Avatar
Liked 22 Times on 16 Posts
Default What can I scrounge smallish metal gears out of?
I have been thinking about some possible future builds, and I think I'll need some metal gears. I've got some gears out of a car gearbox, which look good for the big stuff, but I'm wondering where to look for smallish metal gears. I would like some hints about what I can scrounge some out of.
Steadily following the "Up Road"
Kaleb is offline
Old 11-18-2010, 10:44 PM   #2
Brian Rupnow
Liked 4003 Times on 3186 Posts
Likes Given: 36
Default Re: What can I scrounge smallish metal gears out of?
Old TV antenna rotors are full of them, also most battery powered electric drills. I have done post on both these items, but you can do a search under "gears".---Brian
Brian Rupnow
Brian Rupnow is offline
Old 11-19-2010, 07:25 PM   #3
student123
Liked 10 Times on 10 Posts
Kaleb,
Depending on the size :
http://www.homemodelenginemachinist....p?topic=9288.0
May help with some more ideas
Mike
student123 is offline
Old 11-19-2010, 08:01 PM   #4
oldben
Liked 4 Times on 4 Posts
try your local office machinery suplyand ask if the have any scraper photocoppy machines they are full of small gears and bearings
Old Ben
oldben is offline
Old 11-19-2010, 11:19 PM   #5
bentprop
Liked 17 Times on 17 Posts
The cylindrical battery screwdrivers usually have a planetary gearbox with nice little metal gears in them.Same for batt.drills.
I second the photocopier idea,they also have lots of lovely small diameter shafting in them.Most of the gears tend to be a form of plastic though,and many are spiral or worm types.
When you say"smallish",how small are you looking for?
As a last resort,you might have to look at rc car gears.
Or,if that size is too small,how about a motorbike gearbox?Gears aplenty.
Hans.
bentprop is offline
Old 11-20-2010, 01:38 AM   #6
lathe nut
Lathe Nut
lathe nut's Avatar
Liked 36 Times on 35 Posts
found a printer on the side of the road the other day, full of gears, rods and springs not even counting the rollers and old VCR'S, Lathe Nut
lathe nut is offline
Old 11-20-2010, 01:40 AM   #7
lee9966
Liked 11 Times on 11 Posts
Old circular saws have nice bearings and gears.
lee9966 is offline
Where to scrounge strong stepper motors from? Dinkum CNC Machines and Conversions 15 06-29-2012 12:03 AM
Gears wesley General Engine Discussion 1 01-14-2011 08:47 PM
Boring smallish diameters (below about 15mm) Kaleb General Engine Discussion 3 01-31-2010 03:17 PM
Preventing damage by metal on metal Bogstandard Tips and Tricks 7 05-02-2008 04:45 PM
Metal Gears for Mini Lathes Cedge Machine Modifications 3 12-11-2007 09:59 PM
