Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Tools > Needed to counter sink a 4/40 socket head cap screw
Old 02-02-2008, 03:06 AM   #1
deere_x475guy
Liked 32 Times on 31 Posts
Default Needed to counter sink a 4/40 socket head cap screw
Well I finally got some time to get back into the shop this evening. Task at hand was to counter bore the head I am making for the my Webster engine. The 4-40 heads are approximately .215 and the only end mill I have that was large enough is .250. Not wanting to go that large I decided to try to make my own from a M42 drill I had laying around that miked out around .233. I am lucky enough to have a end mill sharpening fixture and a surface grinder. While I have sharpened plenty of end mills I never tried to make one from a drill before. It turned out ok and did the job, however if I am going to use this one again I need to shorten it up. I ended up with some chatter and I am sure it is due to the lack of rigidity from the length. Any where I know how you guys like pics so here are a few.
Hopefully I will have something to post in the progress area soon...
Skype# boba1618
http://www.d1adaptersolutions.com/
Kind Regards
[[url=http://s2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/]http://s2.photobucket.com/albums/y39/Deere_X475guy/M
deere_x475guy is offline
Old 02-02-2008, 03:18 AM   #2
raym 11
raym 11's Avatar
Liked 4 Times on 4 Posts
Default Re: Needed to counter sink a 4/40 socket head cap screw
I wonder if leaving a pilot on the end might help with the chatter?
raym
not always right ,
but never wrong
raym 11 is offline
Old 02-02-2008, 06:21 AM   #3
cfellows
cfellows's Avatar
Liked 759 Times on 487 Posts
Likes Given: 3
I also wonder if you might not partially drill out the hole with an unmodified m42 drill bit, then flatten the bottom of the hole with the ground off m42?
Chuck
cfellows is offline
Old 02-02-2008, 02:28 PM   #4
Bernd
Liked 25 Times on 25 Posts
Or you can make one from drill rod with a pilot on it. The c'bores should be run slow and with a lube on them to get better finish. Harden if used on steel, don't need to harden if used on brass and aluminum.
Bernd
You can't fix stupid!
Bernd is offline
Old 02-02-2008, 02:35 PM   #5
deere_x475guy
All of you guys have great alternate solutions
Bernd, can you how did you go about making your bit?
Skype# boba1618
Kind Regards
Old 02-02-2008, 03:33 PM   #6
AllThumbs
Liked 9 Times on 9 Posts
Being lazy I just use a drill and leave the hole bottom tapered for the really small bolts Then again I am an electrician by trade.
Accuracy is adjusting the second part to compensate for an error in the first....
AllThumbs is offline
Old 02-02-2008, 03:54 PM   #7
Stan
Liked 31 Times on 31 Posts
With piloted counterbores available for $5.00 or $6.00 each, I can't justify the time to make one. I expect the ones I bought some twenty years ago were about $2.00 each and they have served me well in both aluminum and steel. I bought a machine screw set plus a 1/4". Anything bigger than that, (which is rare) I use a drill bit followed by an end mill.
Unless I am making something that uses a large number of one size screw, I buy socket head cap screws by the box (100) in 1" length and cut to length with a Dremel cutting wheel. For the occasional long screw I buy a few at a bolt supply and have some for the next time.
Stan in Leduc, Alberta, Canada. 53.40NĀ* 113.5W
Old, but still on the right side of the grass.
Stan is offline
Old 02-02-2008, 04:29 PM   #8
deere_x475guy
Stan your right, you can buy them but this was more about the challenge of making one, and the things I learned along the way. Plus I wanted to do the counter boring last night
I also buy the most common size cap screws that I use by the 100. I think the last lot I bought was close to $5.00 for the box. The local Ace hardware gets .30 each.
Skype# boba1618
Kind Regards
Old 02-02-2008, 07:57 PM   #9
Stan
deere: As I have said in previous posts, I have spent more time making tooling than making models. The rate of success that I have had hardening and tempering tools, I probably made my rotary table in less time that it would take me to make a set of counterbores.
With imported tools, that are adequate quality for HSM use, there is no need to not have the small basic tools. When I started in this hobby, a cheap indicator was over $100.00. Now, I probably have six that cost less than $10.00 each mounted to various attachments to quickly stick on the lathe or mill.
I don't feel that I have put any American workers out of work by buying import tools. If my only choice was Starrett, I just wouldn't have bought any new tools. I now have a lot of US made tools that were bought used but took years to accumulate
Stan is offline
Old 02-02-2008, 09:00 PM   #10
raym 11
raym 11's Avatar
deere;
I think the bigger concern to me would be the raised up burr on the periphery of the holes on the face of the part. What could cause that if you had a evenly sharpened and straight bit unless the material was some tough.
raym
not always right ,
but never wrong
raym 11 is offline
Small socket wrenches ghart3 Tools 9 03-24-2010 04:20 PM
Purpose of allen head "indexing" screw in 5c collet block JMI Tools 1 12-30-2009 05:55 AM
Piston Rings, Socket Head Cap Screws, Set Screws HughT General Engine Discussion 17 03-18-2009 02:55 AM
Why so many socket head cap screws? SmoggyTurnip General Engine Discussion 11 08-12-2008 08:52 AM
Counter Sink Cutter Bernd Tools 2 02-01-2008 01:11 AM
