Project of the Month built by sbdtasos
Home Model Engine Machinist > The Tools and Tips > Machine Modifications > Epoxy fillings for SC2 mini lathe
Old 12-27-2016, 10:46 PM   #1
oxotnik
Liked 34 Times on 20 Posts
Likes Given: 5
Default Epoxy fillings for SC2 mini lathe
The SC2 mini lathe bed is hollow cast iron. Strength and rigidity can be significantly improved by fillings; the material is epoxy bonded quartz gravels.
Photos:
oxotnik is offline
Hopper Likes This
Old 12-28-2016, 04:06 AM   #2
Hopper
Liked 115 Times on 96 Posts
Likes Given: 119
Default
Nice. Has it made a noticeable difference in surface finish etc?
Hopper is offline
Old 12-28-2016, 08:26 AM   #3
oxotnik
Likes Given: 5
Default
Hi. It makes the world's difference; now post-mod it cuts machining steel almost as easily as alu pre-mod. Also I've done the same treatment to the rest of lineup, i.e. X1, SU1, AT125, etc...
oxotnik is offline
Hopper Likes This
Old 12-28-2016, 10:24 AM   #4
Niels Abildgaard
Liked 90 Times on 82 Posts
Likes Given: 36
Default
My Boxford on granite turns hardened steel.
If combined with Your epoxy it will turn diamond to optical quality.
http://i.imgur.com/WvKsXOd.jpg
Kind regards
Niels
Niels Abildgaard is offline
Old 12-29-2016, 12:43 AM   #5
ninefinger
ninefinger's Avatar
Liked 32 Times on 26 Posts
Likes Given: 16
Default
Have any details on the mix you used? I.e. ratio of gravel to epoxy? Its tempting to do on my Compact5 as it won't cost that much, but doing anything to my mill will be expensive...
Mike
ninefinger is offline
epoxy release agent kd0afk Tips and Tricks 9 02-08-2014 08:24 PM
my mini sX2 mill and mini 7x12 lathe mods (so far!) MCRIPPPer Machine Modifications 14 09-19-2013 03:23 PM
Epoxy won't set chucketn General Engine Discussion 3 07-30-2011 11:02 PM
Epoxy vs polyester for thermal conductivity. picclock General Engine Discussion 8 07-11-2011 04:19 PM
Epoxy rwells General Engine Discussion 4 04-13-2008 04:15 PM
