Home Model Engine Machinist > Building Them > Plans > Plans for Carburetor?
Old 11-02-2016, 11:17 AM   #1
neil_1821
Liked 4 Times on 4 Posts
Default Plans for Carburetor?
I've been doing a lot of googling and searching on this forum and I'm still struggling to find a source for plans.
I'm looking for carburettor plans specifically for the hoglet V twin engine. I understand you can use a model engine one but it just doesn't seem to fit the overall look of it. I have seen some with nice carburettors but I can't get any further.
Can anyone point me in the right direction?
neil_1821 is offline
Old 11-02-2016, 04:18 PM   #2
stevehuckss396
Senior Member
stevehuckss396's Avatar
Liked 952 Times on 642 Posts
Likes Given: 8
Default
Try jerry Howell's web site. His son sells all his dad's drawings and the two jet carb is also available. A little bit of work in Google and you should be able to find your way there.
stevehuckss396 is offline
Old 11-02-2016, 04:56 PM   #3
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Liked 715 Times on 536 Posts
Likes Given: 77
Default
Jerry Howell plans for carb. very nice carb with good build instructions, and very cheap at around 8.5 bucks if you download the PDF.
http://www.model-engine-plans.com/en...2jet.htm?26,18
If you don't try it, you will never know if you can do it!!
Blogwitch is offline
Old 11-02-2016, 10:32 PM   #4
neil_1821
Default
Excellent, thanks chaps.
Old 11-02-2016, 11:45 PM   #5
lantain1982
Liked 7 Times on 7 Posts
Default hoglet carby.
Recently completed my Hoglet. Used Jerry Howells twin jet carby.
Down loaded the plans. As noted good clear drawings and notations.
Two options given. I used the fuel inlet at 45 degree option but in hind sight I should have used the alternative which is more suitable for the Hoglet application.
Once I mastered the needle valve settings the carby responds very well over the full
throttle range.
lantain1982 is offline
Old 11-03-2016, 11:59 AM   #6
Gordon
Liked 59 Times on 42 Posts
Likes Given: 7
Default
I have just completed the Howell V-2 and I am using the carburetor designed by Brian Rupnow and George Britnell and it seems to be working well. Plans can be found as part of the Rupnow build of the vertical as found on post #136 of
http://www.homemodelenginemachinist....rtical&page=14
Gordon is offline
Old 11-03-2016, 12:09 PM   #7
Brian Rupnow
Liked 4125 Times on 3271 Posts
Likes Given: 37
Default
Gordon--that isn't my version of the George Britnell carburetor. That is my version of the Malcolm Stride carburetor as originally used on the Jaguar and Bobcat engines.--Brian Rupnow
Brian Rupnow
Brian Rupnow is offline
Old 11-03-2016, 12:23 PM   #8
Gordon
Likes Given: 7
Default
Brian: You are correct. I used your Rupnow/Britnell design which I had picked up where you posted it on another forum. Not sure now which forum. I modified your drawings and one I received from George to fit my needs and tooling. I had not paid enough attention to your vertical drawings and just thought that they were the same. Thank you to both you and George for your work on carburetors. They give a good starting point for building a carburetor.
Gordon is offline
Plans for making a carburetor mrputz1 General Engine Discussion 0 10-17-2014 09:52 PM
Carburetor cfellows A Work In Progress 13 05-20-2012 07:57 PM
Carburetor nfk General Engine Discussion 8 10-25-2010 10:33 PM
Carburetor plans? Maine Ronin Plans 6 06-07-2010 01:34 PM
Plans for a small hit miss carburetor SOS bigal2749 General Engine Discussion 4 10-23-2009 04:01 AM
