Project of the Month built by edholly
Home Model Engine Machinist > The Tools and Tips > Machine Modifications > 7x12 metal gears
Old 01-10-2017, 11:53 PM   #1
zoltan
Liked 11 Times on 10 Posts
Likes Given: 30
Default 7x12 metal gears
If someone has changed both the 7x12 headstock gears hi-lo gears to the metal ones, would you mind telling me how much louder they are than the stock plastic gears?
I'm replacing the spindle hi-lo gear with a metal one, and I'm trying to decide if I should replace the countershaft one with metal as well, or just leave it plastic.
zoltan is offline
Old 01-11-2017, 02:23 AM   #2
oldboy
Liked 3 Times on 3 Posts
Likes Given: 73
Default
They sounded a bit louder when first used, however once the settle in and get a couple of hours use they are not all that much louder. That's my take on them, same applies to using metal change gears.
Barry.
oldboy is offline
Old 01-11-2017, 01:45 PM   #3
John S
Liked 71 Times on 60 Posts
Likes Given: 8
Default
Leave the countershaft one plastic as a fail safe. The countershaft is easier to change in the event of a snag but the spindle one is a lot harder.
John Stevenson [ was JohnS the 3rd.]
Nottingham, England
John S is offline
Old 01-11-2017, 01:52 PM   #4
zoltan
Likes Given: 30
Default
If I change both spindle and countershaft to metal gears, what would break?
zoltan is offline
Old 01-11-2017, 08:14 PM   #5
John S
Likes Given: 8
Default
Probably burn the motor out or the speed board.
Nottingham, England
John S is offline
Old 01-31-2017, 05:37 PM   #6
zoltan
Likes Given: 30
Default
If you go with all metal, how often do you need to grease them?
zoltan is offline
Old 02-01-2017, 05:35 PM   #7
Wizard69
Liked 159 Times on 143 Posts
Default
Depends, niether the motors nor the controllers are known to be rugged (at least on the base machine). That doesn't mean a belt or something else wont give up mechanically. Jams often damage leadscrews or shear pins
Wizard69 is offline
Old 02-01-2017, 10:24 PM   #8
velocette
velocette's Avatar
Liked 32 Times on 27 Posts
Likes Given: 8
Default
Hi Zoltan
Have you considered a belt drive using 4 rib "Poly Vee Belts" and dump the gear drive. Added a PDF File of the pulleys for a mini mill drive on my X2 Mill may be of some help.
Eric
velocette is offline
Old 02-02-2017, 04:31 PM   #9
zoltan
Likes Given: 30
Default
Once I got into my lathe rebuild I did start looking at something like that, except I need a lathe to make the pulleys...
Hopefully I can make this happen after I get my lathe back together.
zoltan is offline
Old 02-03-2017, 07:44 AM   #10
Wizard69
Default
Poly V belts make for very nice mechanical drive solutions.
Wizard69 is offline
LMS HiTorque 7x12 Mini Lathe with Tooling gus Tools 3 09-16-2014 01:11 AM
3" steady rest for 7x12 lathe MCRIPPPer Machine Modifications 15 07-08-2014 12:30 AM
Pro Tek 7x12 lathe question skypup Machine Modifications 0 09-05-2012 07:26 PM
What can I scrounge smallish metal gears out of? Kaleb General Engine Discussion 6 11-20-2010 01:40 AM
Metal Gears for Mini Lathes Cedge Machine Modifications 3 12-11-2007 09:59 PM
