Project of the Month built by Rustkolector
Home Model Engine Machinist > Showing Them > Photos and Videos > Scraps and Solder Become an Engine
Old 11-15-2016, 12:39 PM   #1
The_Paso_Kid
Liked 62 Times on 30 Posts
Likes Given: 18
Default Scraps and Solder Become an Engine
I built this steam engine based on the December 1950 article by that title in Popular Science magazine. I used a little less solder than what the original plans called for.
It runs great.
The_Paso_Kid is offline
9
People Like This
Old 12-13-2016, 12:24 AM   #2
bwal74
Liked 8 Times on 7 Posts
Likes Given: 93
Default
Hi,
Any chance you could post the plans or where to find the plans?
Ben
bwal74 is offline
The_Paso_Kid Likes This
Old 12-13-2016, 05:13 AM   #3
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Liked 693 Times on 517 Posts
Likes Given: 73
Default
It's nice to see these old style barstock engines still being made and run.
It was only a few years ago that 'Elmers' engines were all the rage on here, but it seems to have died down a lot.
It gave the beginners to this hobby a chance to make something that could fairly easily be made and run without costing a fortune, plus they gave them the experience to move onto more complicated engines.
Very well done indeed TPK.
If you don't try it, you will never know if you can do it!!
Blogwitch is offline
Old 12-14-2016, 06:02 PM   #4
The_Paso_Kid
Likes Given: 18
Default Link to the Dec 1950 issue
Here is the link to the December 1950 issue of Popular Science magazine on Google books website. It is copyrighted material, otherwise I would have posted copy of the plans here.
The article is on pages 196 and 197.
https://books.google.com/books?id=yy...page&q&f=false
Old 12-15-2016, 07:59 AM   #5
bwal74
Likes Given: 93
Default
Thanks for the link. Great old mag to read, funny how times have changed!
I forgot to ask what did you use for the flywheel? It looks like a old tap (facet) handle.
Ben.
bwal74 is offline
Old 12-15-2016, 11:30 PM   #6
The_Paso_Kid
Likes Given: 18
Default Flywheel
I adapted the plans to utilize materials I had on hand. I drilled and tapped to attach parts together rather than use solder to secure the parts and pieces together as per the plans. The flywheel was actually from a broken toy gyroscope it made a perfect flywheel.
Old 12-16-2016, 04:47 PM   #7
IceFyre13th
Liked 9 Times on 8 Posts
Likes Given: 8
Default
I am currently modeling and creating drawings for this engine in SolidWorks, I will put the 2D PDF files out here when done as well as some renderings.
Using the Popular Science link from above for the base and adding a few improvements along the way to make it easier to build.
If there are any others that you would like done let me know...............
IceFyre13th is offline
Old 12-17-2016, 03:05 AM   #8
lathe nut
Lathe Nut
lathe nut's Avatar
Liked 36 Times on 35 Posts
Default
how do you save it to file
lathe nut is offline
Old 12-17-2016, 02:54 PM   #9
The_Paso_Kid
Likes Given: 18
Default My plans
I dug around my files and found this sketch I had done while modifying the plans to suit the materials I had on hand.
Hopefully everything is legible and clear.
Old 12-19-2016, 04:50 PM   #10
IceFyre13th
Likes Given: 8
Default
Quick picture of the SolidWorks Model.
Have to figure out the correct valve rod and arm lengths then I will be starting on the 2D drawings.
Solder FS 1hand Buy / Sell / Trade / eBay 1 02-04-2013 02:58 AM
Solder without flame..... steamertate General Engine Discussion 5 12-03-2011 12:47 PM
Which solder Herbiev General Engine Discussion 16 06-16-2011 07:26 AM
Which solder to buy dnp101677 General Engine Discussion 6 02-05-2011 12:15 AM
silver solder vs. soft solder Twinsquirrel General Engine Discussion 2 10-21-2008 12:50 AM
