Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Tools > Band saw
Old 10-24-2017, 03:01 AM   #11
john_reese
Liked 4 Times on 4 Posts
Likes Given: 5
Default
Originally Posted by Wizard69 View Post
This is an important point, you might not have the power needed by going to a variable speed motor solution. However given that is ti fairly easy to get a 10- 1 reduction from a single stage belt drive which puts a variable speed motor is a far better position for delivering power.
Many years ago my brother and I adapted a Delta wood cutting saw for metal. We modified an old coal stoker gear box as a reduction gear. I believe it gave about 20:1 reduction. That gearbox had its own motor .. We mounted that gearbox and the original motor so we could run the belt to either one depending on what we were cutting. The stoker gearbox had a worm gear reduction followed by a planetary reduction. We eliminated the planetary stage. The stoker gearboxes used to be used to turn the spit on hog roasters. Unfortunately most of those gearboxes were scrapped many years ago. We got lucky and found one in a scrap yard around 1960. A used 20:1 worm drive would work nicely.
john_reese is offline
Band saw upgrade Rudy Machine Modifications 10 10-26-2017 02:16 PM
band saw blockmanjohn General Engine Discussion 7 12-08-2016 01:21 AM
Band saw blades purpleknif General Engine Discussion 9 10-24-2015 03:55 PM
My take on 4 X 6 band saw modifications CallMeAL Machine Modifications 6 04-14-2014 12:03 AM
Band saw mod?? wla421 Machine Modifications 11 01-03-2011 04:55 PM
