Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Tools > BAZMAK a second Lathe
Old 08-27-2017, 08:04 PM   #131
goldstar31
Liked 357 Times on 305 Posts
Likes Given: 558
Default
Originally Posted by JCSteam View Post
Hi Norm, the bar stock can act as a slider one clamped to the bed of the cutter, the other for sliding against it. The brass gib piece can be glued to the top of the slider bar and passed through easily, (theory sounds good anyhow) On the next cut reverse the brass which can now be held against the first cut on the slider, below where the brass was glued. So long as the blade is not adjusted a parralel gib slide is now made and just requires honing in. If you still not with me, im not good at explaining myself, maybe a diagram may help explain better.
You are right though, sharpening drill bits would be easier if nothing else.
If the glue doesn't hold, then soft solder and when finished sweat it off.
None of this lead free solder- I add!
N
goldstar31 is online now
JCSteam Likes This
Old 08-28-2017, 12:20 AM   #132
bazmak
BAZMAK
bazmak's Avatar
Liked 1049 Times on 591 Posts
Likes Given: 827
Default
I have resurrected a couple of photos where i made a new brass gib without a mill using a cheap belt/disc linisher.Very cheap from Aldi etc and can be
very useful to cut doewn on filing etc.Did many mods and its now worth its weight in gold.An essential piece of kit to a newbie.If anyone is interested
i can ressurect the threadClick image for larger version
bazmak is offline
2
People Like This
Old 08-28-2017, 05:53 AM   #133
bazmak
BAZMAK
bazmak's Avatar
Likes Given: 827
Default
Well i polished up the gibs and set the compound.The cross slide had a well fitting gib and i had already fitted additional screws so it was just a case of
resetting etc.The carriage was the big problem so had to take a few thou off
the front gib plate and reset.Everything is now A OK .I wonder how long it will last.One thing did surface.The front carriage gib plate can only be adjusted
when the whole assy is diassembled however on the first photo i have highlighted with a sharpie that on this model the 2 end studs could be drilled
thru the carriage with fixings on the top,making it much easier to set and
perhaps be used as a carriage lock.If i lose the settings and have to strip down
again i might try it.Also made a quick change alum chip tray.My dormant
sheetmetal work skills came to the fore.Brought back memories of over
50 years ago at trade school when the exams were to develope and make
things like water jugs and milk churns from tin plate. Wish i could go back
bazmak is offline
Old 08-28-2017, 09:07 AM   #134
JCSteam
Liked 55 Times on 49 Posts
Likes Given: 285
Default
I like the chip tray idea
Also if you could find the thread on the sander that would be helpful to me I haven't fully got to grips with the site just yet
JCSteam is offline
Old 08-28-2017, 10:06 AM   #135
goldstar31
Likes Given: 558
Default
The 'English' version of the belt sander becomes available from time to time at either Lidl or Aldi and probably cheaper than generally available from other suppliers.
In all.it is not too bad although a bit flimsy on the rests. I usually buy the various grades of grit belts and put them into stock. I have one and simply have learned to live with its foibles.
With a bit of 'judicious jiggling', I'm assured that grinding hss tooling is possible.
I'm sort of happy to use one often because I forget where I put my files! The shame of it all!!!!
Norm
JCSteam Likes This
Old 08-29-2017, 12:44 AM   #136
bazmak
BAZMAK
bazmak's Avatar
Likes Given: 827
Default
The Clark branded version is sold by machinery mart in the UK
I bought one here in OZ for $70 for woodworking,for quickly and
accurately squaring end grain on timber for dowelling joints
The sander is very cheaply made in some areas like the mini lathe
but has the potential to mod to a high standard as the 7x lathe
The driven roller is on plastic bushes and quickly wear out,my first mod
was to make brass bushes,but lubrication is difficult so fitted cheap skate bearings.Also made a dedicated stand and increased the 6" disc size to 9"
to accept velcro fitting discs. The things i can do with it in metal and wood
you would not believe.Worth its weight in gold.If it blew up tomorrow i
would go out and buy another even at twice the price.Sharpening tooling etc
And heavy filing is a thing of the past.I will resurect the thread and post more
photos
bazmak is offline
JCSteam Likes This
Old 11-14-2017, 10:21 PM   #137
bazmak
BAZMAK
bazmak's Avatar
Likes Given: 827
Default Reposted for David Builder 01
Have reposted this for builder 01 and anyone else who may find it interesting
bazmak is offline
BAZMAK-DIARY of a NEW SIEG SC4 LATHE bazmak Tools 63 02-10-2018 05:17 PM
Bazmak-HELP blown up the lathe bazmak General Engine Discussion 11 03-13-2015 05:05 PM
BAZMAK Diary of an Advance Lathe refurb bazmak Machine Modifications 18 03-13-2015 03:06 AM
Bazmak diary of a 7 x 16 sieg mini lathe bazmak Introduction 45 02-12-2015 02:23 AM
Bazmak A t slot faceplt for the Sieg lathe bazmak Tools 5 09-11-2014 01:08 AM
