Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Tools > The beginners tool box
Old 08-03-2013, 06:12 PM   #61
MCRIPPPer
Liked 63 Times on 39 Posts
Likes Given: 3
Default
i will put a +1 for a good file. i like single cut files because they work great for getting the bur off after milling or turning. get a good quality file and you can create smoother surface than milling! im pretty sure the files i have are second cut. if you keep them clean they will cut like crazy. you really only need one or two nice ones.
MCRIPPPer is offline
robcas631 Likes This
Old 08-03-2013, 09:20 PM   #62
Tin Falcon
Tin Falcon's Avatar
Liked 814 Times on 647 Posts
Likes Given: 18
Default
Transfer punches are a tool not yet mentioned. Like drill bits they come in many sizes 115 different sizes for imperial and then of course a metric set.
the idea is you have a part that needs to mate to another part you . The first part has holes in it the second part needs holes that align with the first part . you clamp the two together then use these punches to "transfer"hole locations.
these are available from many vendors and the presentaion may vary from tool roll to plastic or metal stand.
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 08-05-2013, 12:25 AM   #63
gus
gus's Avatar
Liked 1161 Times on 815 Posts
Likes Given: 1539
Default
Transfer Punches.
Long time ago,thought these were essential items. Drilling matching holes to accept flanges was a hit & miss and pain in the side.
After buying one set from UK vendor and all my mismatching woes are over.
Gus now looking for other essential tools not discovered.
Oh Yeah!!! Corner radius mills.
Looking for brand new old fashion H.T. Ignition Coil for Webbie equally tough.
Gus,the Happy Boat-Fisherman and Happy Machinist.
(Jack of all Trades and Master of None)
gus is offline
Old 08-05-2013, 09:58 AM   #64
Hopper
Liked 147 Times on 121 Posts
Likes Given: 133
Default
A good old-fashioned hacksaw was one of the items in my first year apprentice toolbox.
Indispensable for cutting stock to rough size, seized bolts, slotting, parting (ok ok sit down in the back row) and with a 10" bastard file and 10" millsaw file can substitute for a milling machine in many instances.
Always slacken off the wing nut after use so the blade is not under tension during storage. This stops the frame from bending and getting slack over the years. My apprentice hacksaw is still in use in my home workshop 40 years later. I still find its use much more "therapeutic" than a noisy angle grinder that throws sparks and grit all over the shop.
Hopper is offline
Old 08-14-2013, 01:55 AM   #65
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
Default
How about 1-2-3 blocks.
many used for setup and layout.
Old 08-14-2013, 04:12 AM   #66
pete
Liked 44 Times on 33 Posts
Likes Given: 43
Default
Originally Posted by terrywerm View Post
How about a dial indicator, magnetic base, and dial test indicator set?? This one is from littlemachineshop.com
How can or could anyone argue with Terry's points? The thread title was "Beginners tool box" Ok fine, a DI and DTI really aren't optional, and..........will never be optional in my simple and humble opinion. However I can't say the same for a lot of the other optional tools others have listed here.
I could I guess mention a decent range of educational books. Anyone remember books? I don't know about anyone else, but learning and understanding how to think about all this is just as important as the latest damn tool you can buy.
Learning and understanding that concept takes a hell of a long time. At least it did for me.
Pete
pete is offline
Old 08-14-2013, 10:01 PM   #67
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
Default
So Pete show us your list of beginners essentials.
and what do think is missing from our list?
Old 08-15-2013, 12:20 AM   #68
gus
gus's Avatar
Likes Given: 1539
Default
May I suggest feeler gages to set ignition contact points?
gus is offline
Old 08-15-2013, 12:36 AM   #69
Alchymist
Alchymist's Avatar
Liked 18 Times on 14 Posts
Likes Given: 37
Default
I have 4 or 5 sets of feeler gauges here and there among the tool boxes. Most haven't been used much. Not a lot of points ignition systems anymore, even on small gas engines. Not that they aren't handy for some other things.....
Alchymist is offline
2
People Like This
Old 08-15-2013, 01:11 AM   #70
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
Default
Here is an import kit from Travers tools
$ 154 so likely import but nice small box to keep the tools in and sows the basics.
2
People Like This
beginners questions Atzerath General Engine Discussion 4 08-11-2012 07:55 AM
Easy CNC A beginners guide to CNC Bill Gruby General Engine Discussion 14 03-01-2011 09:50 PM
Reamers for beginners.... MattB General Engine Discussion 2 11-29-2009 07:31 PM
Beginners Resource kustomkb The Break Room 0 11-06-2009 04:19 PM
Stirling Engine for beginners BMyers Plans 1 02-13-2008 10:55 PM
