Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Tools > 123 Blocks
Old 10-01-2010, 12:22 AM   #21
GailInNM
GailInNM's Avatar
Liked 287 Times on 239 Posts
Likes Given: 111
Default Re: 123 Blocks
Victor machine has 25-50-75 blocks.
http://www.victornet.com/subdepartme...-Gage/270.html
Gail in NM
Gail in New Mexico, USA
I would like to be the kind of person my dog thinks I am.
GailInNM is offline
Old 10-01-2010, 01:32 AM   #22
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Liked 694 Times on 518 Posts
Likes Given: 73
Gail,
I am just awaiting a delivery from Victors, if I had known that they did metric ones, I would have ordered some at the same time. Postage is the killer from them to the UK.
I wonder if they suffer from the same problem as the Imperial ones? None thru fitting screws.
Bogs
If you don't try it, you will never know if you can do it!!
Blogwitch is offline
Old 10-01-2010, 04:20 AM   #23
GailInNM
GailInNM's Avatar
Likes Given: 111
Bogs,
The main thing is that if Victor, a USA dealer, has them then other dealers should have them available also. The USA market being rather limited, it would not make sense for them to have them made up special.
I have not looked around as most of my tooling is imperial. If I had a 25-50-75 set I am sure they would get stored in the same general location as my 1-2-3 blocks. I can only imagine the results of a midnight madness mix up with one of each in a setup.
Gail in NM
GailInNM is offline
Old 10-01-2010, 06:31 AM   #24
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Likes Given: 73
Gail,
I keep an eye on all the regular suppliers in the UK, and have never come across them.
Maybe someone like J&L will have them, but you are going to pay way over the top.
Victor have very reasonable prices indeed, and the quality is good as well, it is just that they won't use the cheapo methods of postage, which is such a shame.
One day I will find some, it is not as though my workshop will fall down around me just because I haven't got any.
Bogs
Old 11-19-2017, 06:30 PM   #25
Cromaglious
Default
I really need to make some, i have a hf X2 44991, not the most rigid of machines. Really need to get a 2" vice for it, and a 3" if I can find one cheap enough. My 4" is a bit big, though thats going on a friend's rf-31.
Originally Posted by mklotz View Post
I made a pair of half-size 1-2-3 blocks, i.e., 0.5-1-1.5, and they've turned out to be very handy, used by themselves or in combination with the 1-2-3 blocks.
If you're going to set up to make blocks, consider making a half-size set while you're at it.
Cromaglious is offline
Old 11-19-2017, 06:43 PM   #26
Cromaglious
Default
Originally Posted by GailInNM View Post
Bogs,
..... If I had a 25-50-75 set I am sure they would get stored in the same general location as my 1-2-3 blocks. I can only imagine the results of a midnight madness mix up with one of each in a setup.
Gail in NM
Hence a set of 20-40-60 blocks would make much more sense.
Hmm, I'd use 6mm-1.00 threads, since I always have one 10mm combination wrench near the mill. 8mm-1.25 has a 13mm hex, so that's a contender as well.
New angle blocks for the box steamer Tools 7 03-12-2012 11:11 PM
1-2-3 precision blocks oregonsteam General Engine Discussion 32 09-15-2009 04:18 PM
2-4-6 blocks deverett Tools 1 05-21-2009 07:33 PM
collet blocks kvom General Engine Discussion 1 02-27-2009 09:07 PM
What are 1 2 3 blocks? Brian Rupnow The Break Room 44 12-25-2008 11:53 PM
