Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Tools > Jacobs chuck taper.
Old 11-15-2017, 07:45 PM   #1
blockmanjohn
Liked 1 Times on 1 Posts
Default Jacobs chuck taper.
Hi, I have a Jacobs chuck with a 3MT shank. To use it in my Bridgeport I have to use a 3MT to R8 adapter. The length of this set up is very long and limits the space between the end of the drill bit and the table.
I thought the best solution would be to replace the tapered shank with a straight one and hold it in a collet.
Looking on E-Bay it seems that I need to know which Jacobs taper I have on my chuck.
My questions are, is this a good route to go, how do I determine the Jacobs taper on my chuck and where do I find information on how to make the trade?
Thanks, John.
blockmanjohn is offline
Old 11-15-2017, 10:38 PM   #2
bazmak
BAZMAK
bazmak's Avatar
Liked 1048 Times on 591 Posts
Likes Given: 825
Default
Not expensive to buy a jacobs or keyless chuck with R8.I have a 16mm ,a 13mmmm and i justbought a 10mm on a mt2 for my small lathe
bazmak is offline
Old 11-15-2017, 10:38 PM   #3
stragenmitsuko
stragenmitsuko's Avatar
Liked 48 Times on 29 Posts
Likes Given: 7
Default
How about an r8 to jacobs taper adaptor .
That would maximise the available Z travel
Usually the taper size is stamped on the chuck and or shank .
stragenmitsuko is offline
xpylonracer Likes This
Old 11-16-2017, 01:28 AM   #4
john_reese
Liked 4 Times on 4 Posts
Likes Given: 5
Default
Jacobs chuck removal wedges are cheap. Get a set to match the JT on your chuck. Pop off the MT3 shank and put in the R8.
john_reese is offline
Old 11-16-2017, 03:17 AM   #5
10K Pete
Liked 112 Times on 101 Posts
Likes Given: 195
Default
The chuck body should have a marking like "JT-33" or the like. THAT is the taper in that chuck.
Pete
Just tryin'.....
10K Pete is offline
Old 11-16-2017, 11:14 AM   #6
blockmanjohn
Default
Thanks for all the help. Great to hear from people who know what they are talking about. John
Old 11-16-2017, 12:31 PM   #7
bazmak
BAZMAK
bazmak's Avatar
Likes Given: 825
Default
Just arrived in todays post from China.A 13mm quality keyless chuck
and
R8 sleeve to suit for the mill .Total cost less than $50.Far more accurate and rigid for fine drilling on the mill instead of the 16mm jacobs chuck that came with the mill.Will check of the sleeves to see if the chucks are interchangeable
i think it is a b16 taper
bazmak is offline
Old 11-16-2017, 01:55 PM   #8
Sansspaceship
Liked 8 Times on 8 Posts
Likes Given: 11
Default
Plenty of ideas about the correct way to do it above, so won’t add to that advice. But will add the comment the main reason why i wouldn’t use a collet as first suggested.... unless in a pinch. Is that you will likely increase any runout error.
.adrian
Sansspaceship is offline
Old 11-16-2017, 07:39 PM   #9
Wizard69
Liked 197 Times on 175 Posts
Default
In an ideal world you would have a chuck with an R8 shank and at least one with a straight shank. The idea with respect to the straight shank is having the ability to swap the chuck with straight shank tooling which sometimes comes in handy. Id go with an R8 shanked Chuck first if that chuck is large enough to handle at least 1/2" drills.
Straight shank swappability is taken to great lengths with TTE, the Tormach Tooling System. At work we haven't gone that route yet but do have a drill chuck on a 1/2" straight shank. While not the same as TTS it often is very handy to have a bunch of tooling all with one shank size.
Wizard69 is offline
Jacobs chuck key Coomba General Engine Discussion 24 05-05-2016 07:58 PM
Jacobs chuck Gordon General Engine Discussion 3 12-05-2015 02:00 PM
#34 Jacobs chuck chucketn General Engine Discussion 12 10-28-2015 09:48 AM
Jacobs #100 Chuck Jeremy_BP Buy / Sell / Trade / eBay 4 09-25-2011 05:22 PM
Jacobs taper choice pmerritt General Engine Discussion 5 03-17-2011 08:56 AM
