Project of the Month built by Rustkolector
Home Model Engine Machinist > Building Them > Mistakes, Blunders and Boo Boos > can't believe I did that...
Old 11-24-2014, 11:11 PM   #11
mcostello
Liked 32 Times on 29 Posts
Likes Given: 8
Default
Thats almost as bad as working overtime to finish breakdown parts, and then the foreman says "which ones have the tapped holes?" Made all clearance holes. Parts still worked.
Lancaster, Ohio USA
mcostello is offline
Old 11-25-2014, 01:19 AM   #12
Dale
Liked 2 Times on 2 Posts
Default
looks like the crank wont have much throw ! Don't fret, the next will have more is my bet. I've done it !
Dale is offline
Old 12-20-2014, 12:54 PM   #13
Ken I
Ken I's Avatar
Liked 167 Times on 137 Posts
Likes Given: 5
Default Classic
Believe it or not it took me a few glances to figure out what was wrong.
So I could have easilly done that myself.
I'd rather have a bottle in front of me than a frontal lobotomy.
Ken I is offline
Old 02-08-2015, 03:15 PM   #14
old redneck
Liked 37 Times on 17 Posts
Default
I started to make the exact same mistake, but realized it just as the blade started to cut. On the bright side, it was a good clean cut! Seriously though, I contemplated making mine from scratch and it may have been easier than using the casting. Show us the built up one when you finish.
old redneck is offline
Old 02-19-2015, 05:35 AM   #15
hrefab
Default
Probably the best thing you ever did with a PM casting. Make it up from barstock or cut it compeletly in half and use a dowel pin. Not the worst mistake ever made (by a long shot!)
hrefab is offline
