Home Model Engine Machinist > The Tools and Tips > Machine Modifications > Building a Quick Change Gear Box, need help.
Old 09-30-2010, 04:02 AM   #1
boxcarmj
Liked 1 Times on 1 Posts
Default Building a Quick Change Gear Box, need help.
Is there a relationship between the spindle gear (40T) and the leadsrcrew (12TPI)? Is there a formula I need to work out? Thank-you Mike.
boxcarmj is offline
Old 10-01-2010, 07:12 AM   #2
The Artful Bodger
Liked 4 Times on 4 Posts
Default Re: Building a Quick Change Gear Box, need help.
The ratio between the spindle gear and the leadscrew gear is what sets the pitch of threads when you are cutting them and the speed of the carriage movement when you are turning using the feed screw for horizontal feed.
With a spindle gear of 40t and a 12TPI lead screw you could divide 480 by the required TPI to get the number of teeth required on the feed screw.
For example, for a 24tpi thread divide 480 by 24 gives 20, so 20 teeth required on the lead screw. Intermediate gears will not change the ratio provided you do not use compound gears.
Thats my understanding of it all.
The Artful Bodger is offline
Old 10-01-2010, 08:36 PM   #3
boxcarmj
Thank-you, I'll add this to what I have.
boxcarmj is offline
Old 10-01-2010, 08:56 PM   #4
boxcarmj
Artful, what happens when you use compound gears, does this change the ratio, and how? Your answer was very helpful. Thanks, Mike.
boxcarmj is offline
Old 10-01-2010, 11:41 PM   #5
The Artful Bodger
A compound gear is an intermediate gear which is comprised of two gears locked together on the same bearing.
The most common compound gears are those that convert metric to imperial pitches etc, for example a compound gear set of 127T and 120T.
There is a better explanation here:
http://www.schsm.org/html/gear_ratio_calculations.html
Old 10-02-2010, 01:10 AM   #6
kf2qd
kf2qd's Avatar
Liked 41 Times on 43 Posts
Basically - a 1:1 ratio (Spindle:Lead screw) would be 12 TPI. a 2:1 ratio would be 24 TPI and a 1:2 would be 6 TPI. Others ratios as required for the particular TPI.
KF2QD, South Texas
HF MiniMill, HF 7x10
Hardinge UM, Enco 12x36
Sieg KX3 CNC
kf2qd is offline
Old 10-02-2010, 02:50 PM   #7
boxcarmj
Thank-you. I'll out the link, and this is all getting clearer. Mike
boxcarmj is offline
Quick change tool post? Philipintexas Tools 14 05-24-2012 08:06 PM
Quick change toolposts---again Brian Rupnow General Engine Discussion 58 01-19-2011 11:44 PM
Scratch Building a QCTP (Quick Change Tool Post) for my Myford ML7 BenPeake Machine Modifications 6 08-29-2010 02:55 PM
Quick Change Tool Holder cfellows Tools 0 02-18-2009 03:23 AM
quick change tool posts 13AL General Engine Discussion 10 04-15-2008 11:51 PM
